Activity Forums Adobe Premiere Pro Hallo everyone, my question is
  • Hallo everyone, my question is
    Posted by Gil Sabag on February 26, 2013 at 4:27 pm
    I’m using premier cs4 with quadro fx 1800, and my workflow is excellent , but I want to upgrade to cs6, and my question is, will the mercury engine can work with my card so I will have the same workflow that I have now with cs4? I know that my card is not on the list that adobe published for cards that will work with cs4. But I don’t want to invest more money, since I’m already spending for the software, so is there any solution ?
    Gil Sabag replied 13 years, 6 months ago 2 Members · 4 Replies
  • Jeff Pulera
    February 26, 2013 at 9:14 pm
    I would be more concerned about the PC itself more than the graphics card – how old is it? And do you have Windows 7 64 bit OS for CS6? If the PC is 5 years old and you want to edit the latest AVCHD and DSLR-type formats, you may be very disappointed with the performance.
    I checked on the FX 1800 card and it has 768mb of memory, while 896mb is required for Mercury GPU Playback, so it’s not going to work in GPU mode.
    Jeff Pulera
    Safe Harbor Computers
  • Gil Sabag
    February 26, 2013 at 11:27 pm
    Thank u for the response , my pc is 3 years , it got i7 CPU , nehlam 2.6ghhz, motherboard asus pt6 deluxe v2, 12gb ram ddr3.working with windows 7 64bit.
    So do u think with this hardware I only need to upgrade my
    video card and I will have nice workflow ?
    And if so wich card would u recommend to buy but it’s not to pricy?
    Thank u
  • Jeff Pulera
    February 27, 2013 at 3:43 pm
    Adobe has a very short list of approved cards, but *many* Nvidia cards will work just fine. Main thing to look for is minimum 1GB of DDR5 memory in the card. There is a “cuda_supported_cards.txt” file in the Adobe folder that requires modification if using an “unsupported” card. Either add the name of the card to the list, OR you can delete the list and then Adobe just looks at the specs of the card and if it meets minimum needs it will then be used for GPU acceleration.
    Google “studio 1 hack” for detailed info and there is a large list of cards with recommendations as to whether they will work or not.
    Note that the video cards are not Nvidia branded – many manufacturers make the cards using the Nvidia tech inside, such as PNY, which is a good brand.
    The Adobe-approved list can be found here –https://www.adobe.com/products/premiere/tech-specs.edu.html
    Jeff Pulera
  • Gil Sabag
    February 27, 2013 at 3:59 pm
    Thank u
