Activity Forums Adobe After Effects half speed in AE?
  • half speed in AE?
    Posted by Malcolm Desoto on October 1, 2007 at 5:39 pm
    60 fps to 30?
    No matter what time effects I apply to the clip, I cannot extend the clip. I.e. if I apply timewarp to a 60 fps clip, it slows it down, but the clips duration stays the same.
    I’ve read about Twixtor, just don’t have the dough!
    Using AE 7.
    Kevin Camp replied 18 years, 11 months ago 5 Members · 12 Replies
  • 12 Replies
  • John Spencer
    October 1, 2007 at 6:01 pm
    Had a similar problem before.
    I know a good tutorial dealing with this sort of thing.
    check out the tutorial…
    https://www.videocopilot.net/tutorials.html?id=41
    -Spence.
  • Malcolm Desoto
    October 1, 2007 at 6:04 pm
    Mmmmmmmm…yes. I’ve seen that. I guess I should buy Film Magic Pro.
  • Steve Roberts
    October 1, 2007 at 6:10 pm
    Silly question: is the clip the same length as the comp? If so, should the comp be lengthened?
  • Mike Clasby
    October 1, 2007 at 6:15 pm
    I think you need to precompose the clip, open that comp, make it twice as long duration-wise as the clip, so the clip has room to expand wen you apply time warp in the main comp. It’s been awhile since i demoed an AE version with time warp, but it was something along those lines.
  • Malcolm Desoto
    October 1, 2007 at 6:20 pm
    No Steve. The clip is like 00:02:27 and the comp is 00:30:00.
    Okay. I’ll try that Mike. Would precomping do anything to a clip that has no effects applied to it? Wouldn’t that just be like dropping the clip into another comp?
    In the mean time, I went back to Avid ,created a 30 fps clip, and then re-exported.
  • Malcolm Desoto
    October 1, 2007 at 7:04 pm
    Thanks man! Always appreciate the old school tips.
    It’s not interlaced, so that won’t be an issue.
  • Mike Clasby
    October 1, 2007 at 7:30 pm
    OK, I think I remember now.
    In the Project Window, select the footage being warped (in the comp below), Right Click, Interpret Footage>Main, and then change Other Options>Loops to 2 (near bottom of panel).
    Now, in the timeline, you can drag the right end of the footage out to the length needed.
    No?
    There’s framerate stuff in that anel too.
    I know I need to upgrade, myBad.
  • Malcolm Desoto
    October 1, 2007 at 8:38 pm
    coool. Thanks for the advice guys. I’ll try all of the above and see what works best.
  • Kevin Camp
    October 1, 2007 at 9:09 pm
    personally i use dave’s method… i had figured it out a while ago, and i just stick with it…
    but maltaannon has a slow-mo tutorial that should work that sounded like you may not need to adjust the interpret footage settings, just apply a preset to get half-frame rate slow-mo. it was for interlaced footage, but i would think it would work for 60p to 30p just fine.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Malcolm Desoto
    October 2, 2007 at 12:28 pm
    ha ha. Agreed.
