Activity › Forums › Adobe After Effects › half sized video for web
  • Elad Menashe
    March 3, 2006 at 3:05 pm
    1) First choose the composition you want to render and Composition>Make Movie (or Ctrl+M)
    this will open the Render Queue
    2) Choose Composition>Add Output Module (in case it is not selectable, select the name of the composition you want to render in the render queue)
    3) Set first output module to your PAL full size configuration
    4) In the second output module enable the Strech checkbox, and specify required width and height (this will render original size and scale it)
    * Note that you do not need to create a second output module if you only want full size or half size, it was added only that the movie will be rendered only once into two different formats/sizes/whatever
    hope it helps.
    Elad
  • Jatin Makwana
    March 3, 2006 at 4:50 pm
    should the pixel ratio matter? as the half size clip is for the web.
    Jat
  • Steve Roberts
    March 3, 2006 at 5:14 pm
    You should use square pixels for the web.
