Activity Forums Zaxwerks Half ring
  • Half ring
    Posted by Doug on September 28, 2006 at 11:10 pm
    Hello,
    I am trying to make half a ring. I have a half circle path with two anchor points a stroke of 1 and no fill. The problem is, when I import into zaxwerks the half circle is there but now there is a line connecting the two anchor points. What do i need to do in Illustrator?
    Thanks in advance
    Doug
    Jon Okerstrom replied 19 years, 11 months ago 3 Members · 3 Replies
  • Doug
    September 28, 2006 at 11:50 pm
    I think i got it
  • Michael Hancock
    What did you do to get it to work?
    Mike.
  • Jon Okerstrom
    September 29, 2006 at 1:24 am
    Hi Mike,
    Invigorator will attempt to close open paths. One solution is to outline the stroke in Illustrator. This creates a filled solid object representing the half circle. Another alternative would be to create a transparency map to make half of the circle shape invisible.
    Jon
