Activity Forums VEGAS Pro Half of my project is gone!!!! when i had saved it!
  • Half of my project is gone!!!! when i had saved it!
    Posted by Malcom Shaker on February 21, 2010 at 2:06 am
    i saved my project, then i was rendering a clip from my project to make it all into one clip. so i did that and waited about a minute and then it said there was a problem rendering this clip, and so i did it again it said the same thing, and then something popped up, wich i can’t remember excatly but it said something about error ocurred stream or something and my project closed. Then when i tried to open up my project again, and a half of my project was gone!!!!!! What? HOW?????
    PLease help me i was working on this project really hard and it took a long time to makee…
    Please Help Me!!!!!
    Terry Esslinger replied 16 years, 6 months ago 3 Members · 4 Replies
  • Mike Kujbida
    February 21, 2010 at 4:25 am
    The following suggestion apples to Vegas Pro.
    Look for the back-up of your project file.
    It will be in the same folder that your project file is.
    The difference is that it will have a .bak extension.
    For example, the main one is called malcom.veg and the back-up is called malcom.veg.bak
    Copy the back-up file to a different folder and rename it by dropping the .bak portion.
    Now open it.
    You many need to re-direct it to the proper folder locations to locate the media but this is a quick process.
    With any luck, all your project will come back.
    Assuming it does, immediately save it under a new name before you do anything else, preferably in more than one location.
  • Malcom Shaker
    February 21, 2010 at 7:09 am
    It changed the icon of the file to the original of sony vegas logo. The it opened and said
    ” Warning: An error occurred while loading the project file.
    The application does not support this file type.”
    and when i clicked on details it says
    “File c:/user/(User name)/Documents/(File name).veg could not be opened.”
    What should i do?… my brain is about to explode!!!!!
  • Mike Kujbida
    February 21, 2010 at 1:08 pm
    If you’re saying that you got this message after changing the .veg.bak file to a .veg file, than your file has been corrupted for some reason and I can’t think of any other option other than rebuilding the project.
    Sorry 🙁
  • Terry Esslinger
    February 21, 2010 at 5:54 pm
    Did you use two different versions of Vegas (ie 8 and 9) during the making of your video?
