Activity Forums Maxon Cinema 4D Hairy Text in C4D?
  • Hairy Text in C4D?
    Posted by Ruben Gomez on December 2, 2008 at 7:54 pm
    Hi.
    I made a text, then extruded it, and then applied hair; but I can’t get hair in the front face of the text. How can I get it?
    Rob Mcdougall replied 14 years, 5 months ago 4 Members · 3 Replies
  • Adam Trachtenberg
    December 2, 2008 at 9:45 pm
    Make the text editable and then connect the caps and optimize. If you don’t want to make it editable you could try placing the extrude in a connect object and then apply the hair to the connect object.
  • Randy Johnson
    December 3, 2008 at 6:24 am
    In addition to Adams answer you may want to change the extruder caps from Ngons to grid to get better placement of hair.
    /randy
  • Rob Mcdougall
    April 10, 2012 at 10:56 am
    Take your MoText and add it to a Connect object. I switched off the “weld” option in the Connect object to stop the text from warping.
