Activity Forums Maxon Cinema 4D Hair trouble
  • Hair trouble
    Posted by Jack Cook on February 12, 2014 at 8:17 pm
    Having a bad hair day.
    I’m using hair to make some tube worms on the ocean bottom. I’ve got them set up, and colored, but I don’t want them to be straight. When I add Kink or Curl in the material I can preview render them in the editor and I can get them to look how I want them to, but when I render to the Picture Viewer they are curled all the way down to the ground, no matter what the settings are. And I can’t get them to change if I change the settings. What is the secret to making hair behave? Why do they render differntly in the final render than in the editor?
    Jack
    Jack Cook replied 12 years, 6 months ago 1 Member · 1 Reply
  • Jack Cook
    February 12, 2014 at 8:42 pm
    I think I may have found the solution, have to play with it to make sure. I was looking for some sort of gravity setting and I found it in the Forces tab on the Hair object. It was set by default to -9.something. I set it to 0 and it looks like it’s working.
    Jack
