Activity › Forums › Adobe After Effects › Hair removal in After effects or Mocha
  • Hair removal in After effects or Mocha
    Posted by Ho Kim on July 17, 2009 at 9:22 am
    Hi~ All Creative Cow Members
    I have a such a difficulities to mask out hair from regualr film footages. esp woman’s curly hair.
    if anyboby know quick way to remove hair either after effects or Mocha, Can you please guide me in a right way?
    Thanks you for consideration for this matter and Hope you guys have a great day.
    Adios
    From HO
    Ho Kim replied 17 years, 2 months ago 2 Members · 5 Replies
  • Curious Turtle
    July 17, 2009 at 2:38 pm
    Hi Ho,
    If you’re talking about rotoscoping hair, then yes that is a tricky situation. What’s the final result you’re after? What’s the background like?
    If you haven’t shot on a greenscreen, then I hope there’s good contrast beteen background and foreground. Here’s what I’ve done in the past:
    i) Create a hi-con matte, using either luma key, or Calculations and Levels. This will not be perfect, but it is designed to give you a good edge key, to keep in details such as hair.
    ii) Create an inner mask using rotoscoping. You can use mocha if you wish, or After Effects’ own tools depending on the subject. The idea here is to fill in gaps and remove extraneous objects not keyed by your hi-con matte.
    The reason I do it in this order is because roto is time consuming. You want to do as much of the heavy lifting as possible with your key/hi-con matte.
    Good luck,
    Ben
    Curious Turtle Pro Video
    Training | Editing | Support
  • Curious Turtle
    July 17, 2009 at 6:00 pm
    Should also add that you should follow normal keying procedure and draw a quick garbage matte first. Again, try and do as much of the main work using quick methods.
    Cheers,
    Ben
  • Ho Kim
    July 18, 2009 at 12:23 am
    Dear: Ben
    Thanks for sharing knowledge with me.
    There is a woman right in fornt of wall in my scene. I had to seperate woman with the background. It hasn’t shot on a greenscreen. T_T;;
    I did the roto the woman first, and used the level value to create the high contrast matte. The result of body came out good B&W matte, but It dosen’t give me a clean hair matte.
    Should I erase all frame by frame either After effects or Photoshop(using animation sequence)? I am afraid that results get jaggy if I do it frame by frame.
    Thanks for your answer and I saw your lecture, it was really helpful.
    Have a niace day Ben
    From HO.
  • Curious Turtle
    July 18, 2009 at 6:43 am
    Thanks for the compliment. :o)
    If it’s a plain wall, with good contrast with the hair then the above technique should work. You should only concentrate on the hair with one hi-con matte.
    If you can’t get a good enough result using this method, then you’ve got another couple of options:
    i) Compromise on your hair. Depending on the hair style, you can often get away with cutting out some the smaller flyaway strands without affecting the overall look.
    ii) Reshoot, preferably against a good greenscreen. You will spend less time pulling your hair out trying to keep the subject’s hair in, if you reshoot with the idea of creating a key.
    All the best,
    Ben
  • Ho Kim
    July 20, 2009 at 12:11 am
    Thanks Ben.
    I only concentrated hair area (just where I needed) and somehow it came out clean hair matte then, I changed B&W matte layer to stencil Luma in blend mode. extracting only woman in my sequences. I added garbage mask to cover where some gaps in my layer. I am not sure if I did it in proper way, but if I find out better way to solve this matter.
    I will keep posting it.
    Thanks Ben, and Have a nice day. ^^
    From Ho.
