Activity Forums Adobe After Effects Hair overshoot for a character
  • Hair overshoot for a character
    Posted by Zoltán Riskó on September 13, 2017 at 7:32 pm
    Hey guys,
    I would like to add an overshoot effects for my character’s hair by expression. I found Dan’s awesome keyframe overshoot script which is awesome but i would like to modify it a little bit.
    Here is my result now, but not perfect:
    https://1drv.ms/f/s!AlEKHWwr-X-pgc9wK17TctDux98GAw
    Now the hair has 3 puppet pins which are linked to 3 null objects. The null objects have a hierarchy by code so i need to move the parent only.
    But i can only achive the overshoot if ad keyframes to the second and the third null objects too but i want to avoid it.
    Is there any trick to add a parent or something like that to the code so i don’t need to add keyframes to the second and third null object but achive an overshoot effect?
    For example: ( sorry I’m not too good with expressions 😛 )
    freq =thisComp.layer(“Settings”).effect(“Freq”)(“Slider”);
    decay = thisComp.layer(“Settings”).effect(“Decay”)(“Slider”);
    myparent=thisComp.layer(“1”).transform.position;
    n = 0;
    if (myparent.numKeys > 0){
    n = myparent.nearestKey(time).index;
    if (key(n).time > time) n–;
    if (n > 0){
    t = time – key(n).time;
    amp = velocityAtTime(key(n).time – 0.01);
    w = freq*Math.PI*2;
    thisComp.layer(“1”).transform.position + value + 15*(amp*(Math.sin(t*w)/Math.exp(decay*t)/w));
    }else
    thisComp.layer(“1”).transform.position+value
    Thanks guys (and sorry for my english )
    Zoltán Riskó replied 8 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
