Activity › Forums › Maxon Cinema 4D › Hair on cloth tear
  • Hair on cloth tear
    Posted by Martin Andrew on September 27, 2023 at 6:43 am
    Hi guys, I’m using a technique similar to in this tutorial – https://vimeo.com/102159313 where a hairy cloth object tears apart. With the old cloth system this works perfectly well but with C4D’s new cloth setup the hairs don’t follow the torn cloth after it breaks apart, they just go back to their initial position. Been tweaking every parameter I can find but there doesn’t seem to be any fix? I can’t imagine Maxon would make this impossible? Hoping I’m missing something here but the only fix seems to be switching cloth to the legacy solver. Attached is my scene file with new cloth set-up so you can see what I mean
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Brie Clayton replied 2 years, 11 months ago 4 Members · 6 Replies
  • Kouraib Abdmalek
    September 27, 2023 at 9:47 am
    Hi Martin,
    I could not see the attached file, but I would just like to ask you: Does the hair move with the cloth if you move the model? If the hairs do not move with the model, I think this tutorial will have a solution to your problem, as there is an attached file explaining the method.
    I hope this helps you
    https://www.youtube.com/watch?v=dwAUT71pB8o
  • Martin Andrew
    September 27, 2023 at 9:55 am
    Thanks for your comments. Everything moves with the cloth and works perfectly well until the point the cloth tears – at which point the hair snaps back to its initial state. I wondered if it could be a priority issue since that was introduced with the latest cloth engine, but fiddling with that hasn’t helped
  • George Charoupas
    September 27, 2023 at 1:35 pm
    Hello Martin,
    You need to change in the guide section the root from polygon vertex to polygon or polygon area or polygon center. Then it works.
  • Martin Andrew
    September 27, 2023 at 1:42 pm
    You did it! I thought I’d tried everything but somehow missed this part, many thanks!
  • George Charoupas
    September 27, 2023 at 1:46 pm
  • Brie Clayton
    September 27, 2023 at 2:13 pm
    Thank you for this solve, George!
