Activity Forums Maxon Cinema 4D Hair constraint tag not working
  • Hair constraint tag not working
    Posted by Jon Simpson on April 21, 2016 at 5:09 pm
    I have a simple spline set up with hair dynamics and constraint tags on each end point. When I hit play, the spline drops like it should, rope-like and holding fast to the objects at either end. However, if I move either of the objects, the spline does not budge. What do I have set wrong here? The spline should move with the object.
    Brian Jones replied 10 years, 4 months ago 2 Members · 3 Replies
  • Jon Simpson
    April 21, 2016 at 5:12 pm
    To be clear, if I hit play, the spline updates to the new location, but I am not able to move the object in real time in the view port and see the motions of the spline like I do in the tutorial I am using to learn about this.
  • Jon Simpson
    April 24, 2016 at 11:39 pm
    Okay so this appears to be a live update-like setting. Can someone tell me where this is?
  • Brian Jones
    April 25, 2016 at 4:15 pm
    don’t know if there is a setting, maybe it’s something different in the version of C4D what is the tut you were watching?
