Activity Forums Audio H4n: why do i have to push Level at 100?
  • H4n: why do i have to push Level at 100?
    Posted by Olivier Prudhomme on April 2, 2018 at 3:05 am
    H4n
    For some reasons I have to push the level at 100 to get a “normal” recording.
    Is there a way to set up the input level in the menu?
    Thx
    Los Angeles – TV Promo Editor – FCP – AVID
    Olivier Prudhomme replied 8 years, 4 months ago 3 Members · 4 Replies
  • Brian Reynolds
    April 2, 2018 at 7:57 am
    What is the incoming source?
    What input are you using?
    Is it only on that source or others as well?
  • Olivier Prudhomme
    April 4, 2018 at 2:18 am
    should have checked the message alert to see someone was helping ! ☺
    Using the XLR inputs with lav and boom…
    Recording lav on track 1 and boom on 2
  • Tristan Chaika
    May 23, 2018 at 8:09 pm
    The reason you have to crank it up high is because your mics are not sending a very strong signal.
    Could just be the mic just doesnt send a strong signal – some mics are better than others. NTG 2 is notoriously weak, if that’s what you have.
    Could be that the mics have a pad turned on (often -10db used to compensate for extremely loud noises)
    You may be able to lessen the attenuation or boost the gain on the lavaliere if it is wireless. Check the manual.
    If your mics are just weak, you could invest in new mics, at875r is a good strong budget level shotgun. Or you could invest in better preamps for your H4n. Look for a thing called a “FetHead”. They are about $100 each. There are a couple kinds. Both require phantom power, but the “phantom” FetHead will pass power to your mic, which is probably necessary for your boom mic unless it also has a battery. If your lav is wireless, it probably needs the regular FetHead, if it is XLR and requires phantom power, then obviously would need the phantom FetHead.
    Or, you could invest in a better recorder with lower noise preamps (zoom f4 or sound devices mixpre series, even the newer Tascams like the DR701d would be hugely better) that allows you to crank the gain up without introducing a lot more noise.
  • Olivier Prudhomme
    May 23, 2018 at 10:46 pm
    Great info, thx Tristan
