Activity › Forums › Apple Final Cut Pro Legacy › H4N sync drift
  • Posted by Scott Faranda on November 20, 2010 at 11:00 pm
    Hey everyone,
    Ran into a little issue with a play that I’m currently shooting.
    I’ll try and provide you with as much info as possible
    Shot with two cameras (Canon HF20 and HV40) and a Zoom H4n Recorder (for crowd noise).
    One camera’s (HF20) audio was a direct line from the soundboard in the theater.
    The other camera’s (HV40) audio is just the camera’s built-in microphone feed.
    I was able to sync the two camera’s audio perfectly just by dropping the HV40’s audio track backwards 2 frames (because I was in the back of the theater, so there was a slight delay).
    I made a marker when a door was shut on stage to match up all the audio (including the H4n), however the audio from the H4n starts to sync drift after a few minutes and by the end of the sequence it’s completely off. Although no matter how much the H4n sync drifts, the two camera’s audio stay perfectly in sync.
    -Both camera’s are shooting at 29.97fps
    -Audio rate on the camera’s is 48khz
    -Audio rate is 44.1khz on the H4n Recordings (wich are mp3s)
    -Sequence setting is at 29.97 and 48khz for audio rate.
    Is there any way to fix what I already have? and if not I still have two performances that I can shoot, so what should I change so that it all goes according to plan for the next two?
    Thanks in advance.
    Scott Faranda replied 15 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
