Activity › Forums › Apple Final Cut Pro Legacy › H.264 – what is best compression software??
  • H.264 – what is best compression software??
    Posted by Friesencold on November 21, 2005 at 4:52 pm
    I am trying to figure out which compression software to use. I have tried Sorenson Squeeze and compressing straight out of FCP. I am compressing hour long teaching sessions from DVCAM source footage, edited in FCP and then compressed into h.264 streaming videos at 400×300 at a rate of around 300kbps. I need something that will give me exact colors upon compression (i have had troubles with compressing out of FCP with colors being muted, blacks become lightened) and the ability to batch compress. Any help would be appreciated.
    thanks.
    TJ
    Walter Biscardi replied 20 years, 10 months ago 4 Members · 3 Replies
  • Aaron Neitz
    November 21, 2005 at 5:41 pm
    You’ve heard of Apple’s Compressor, right? It’s exactly what you’re looking for.
  • David Bogie
    November 21, 2005 at 7:02 pm
    Start by explaining where you want these files to go, how they are to be viewed and how you are justifying the need for color accuracy since you have no control over the setup of the playback monitor, in most cases. Your output issues from FCP sound like user settings problems. There is nothing inherent in FCP that would cause your image to change that much. However, transcoding between color spaces is tricky and requires careful control over the production pipeline from exposure to output.
    H.264 is simply a codec; you can use it from within almost any Quicktime exporting tool. Batch exporting using Compressor is remarkably easy to set up and even automate. Using 264 on DV is only a valid choice if you need 264’s unique scalability properties, otherwise it’s a waste of time since you cannot improve on the original.
    “Best compression software” is relative, I’m afraid. Pick one from the many reviews that you can find all over the magazine sites and here on the cow and then learn how to use it. It will become the best by default. Aside from plugins or support for esoterics, the only differences between them are their interfaces and costs.
    bogiesan
  • Walter Biscardi
    November 21, 2005 at 7:06 pm
    [friesencold] “I am trying to figure out which compression software to use. I have tried Sorenson Squeeze and compressing straight out of FCP. I”
    Use Compressor at either 800kbps or the LAN setting. Outstanding quality.
    You can see the trailer for our film at http://www.theroughcutmovie.com
    It’s a 4mb file down from a 720p 8bit High Def original.
    Walter Biscardi, Jr.
    “The Rough Cut,” an original short film premiering December 7th in full High Definition in Atlanta.
    rsvp@biscardicreative.com to reserve seats.
    https://www.theroughcutmovie.com
