H.264 VBR encoding in Vegas?
Posted by Dave Jones on November 26, 2011 at 5:05 amHi
I’m looking for a way to render my projects in H.264 using a VBR (Variable Bit Rate, e.g.Constant Quality) codec, using Vegas Studio HD Platinum 11.0Current my workflow is:
1) Shoot and edit in AVCHD 1440×1080 25P @ 12Mbps CBR from my Canon HF G10
2) Render in the same 1440×1080 25P @ 12Mbps CBR (constant bit rate) to a H.264 MP4 file.
3) Use Handbrake to convert the step #2 CBR file into the same 1440×1080 25P H.264 file, but using VBR to reduce the file size. (upload destination is Youtube)
4) Same as step #3 but produce a 480×270 H.264 iTunes compatible MP4 file, also using VBR.Is there a way to get Vegas to use VBR instead of CBR, eliminating step 3 in my workflow?
Maybe some plugin H.264 encoder?
Or is there a VBR option in Vegas I have missed?Thanks
Dave.Mike Kujbida replied 14 years, 10 months ago 4 Members · 10 Replies -
Stephen Crye
November 26, 2011 at 6:08 amHI;
I’m not an expert, but I *think* the MainConcept AVC/AAC (*.mp4) built-in codec in Vegas is H.264 (if I wrong I want some codec guru to correct me!)
I’ve been too lazy to look at the files and find some utility that will report if it is actually H.264.
I use that for YouTube, the Custom button has a variety of settings, some are VBR.
Hope this helps.
Steve
Win7 Pro X64 on Dell T3400, MultiTB SATA, 8GB RAM Vegas 10e x64 DVDA 5.2(build 133) Sony HDR-CX550V
John Rofrano
November 26, 2011 at 5:12 pmAs Stephan said, MainConcept AVC will give you VBR AVC/H.264.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Dave Jones
November 26, 2011 at 10:59 pmThanks guys.
I tried Mainconcept, but it is incredibly slow! Like 30+ minutes to render a 3 minute video!
I’m going to try this workflow:
https://www.jazzythedog.com/testing/DNxHD/HD-Guide.aspxThanks
Dave. -
Stephen Crye
November 27, 2011 at 5:02 amHi Dave;
I only just tonight discovered that method (via a reference in another Cow thread from a guru who has recommended it for some time now). It is fascinating and will drive me deeper into research. I plan to experiment with it when I have time (in the middle of a big project that precludes any fiddling with new stuff … I actually have to shoot many man-days worth of video, not to mention the editing!)
I am puzzled by your report that the MainConcept render takes so long. Not that my computer is super-fast, but I wonder if your render is slow due to lots of FX in the project?
I’ll be interested to know if the multi-step workflow is actually faster. I’m interested in it because of the promise of smoother motion, better de-interlace, etc. I now only upload 1920×1080 files (1280×720 is waaaay to fuzzy on my giant monitor), so I’ll be curious to see how the workflow handles that resolution.
The key step will be this one: >Vegas->DNxHD, because you still have to create the Vegas project with all the effects, transitions, music, etc. , and then render it in Vegas to DNxHD.
I’m also curious if HandBrake (never heard of it before tonight) can accept Huffy .avi as input; I work with Huffy a lot because I have huge drives and Vegas renders to Huffy faster than to .mp4 or .mpg. I’ll be very interested to see if the Avid codec results in a faster intermediate render than Huffy.
Please let us know how this all works for you!
Steve
Stephen Crye
November 28, 2011 at 3:00 amFYI Handbrake accepts the Huffy .avi files without complaint.
Have not had time to put a stopwatch to the processes, or compare the quality of Handbrake vs MainConcept in Vegas yet.
Steve
Dave Jones
November 28, 2011 at 4:08 amI installed the Avid DNxHD codec using the installer provided, but how do I now get this to work with Vegas?
I expected to see an additional option in my Render screen, but I see nothing to do with Avid or DNxHD
What am I missing?All I see is MainConcept, Realmedia, Sony AVC, Video for WIndows, Windows media, and XDCAM options.
Dave.
Stephen Crye
November 28, 2011 at 5:34 amHi;
Having not installed the Avid codec, I can only speculate. However, with Huffy, I initially did not see the Huffy option under Video For Windows (.avi) because I run Vegas x64, and the first Huffy I installed was x32. After installing the x64 version of Huffy, the option was there.
If your x versions match, I would expect to see it as an option under the .mov …
Sorry I can’t help more. I’m kind of leery of installing codecs, I thought long and hard before adding the Huffy.
Steve
Mike Kujbida
November 28, 2011 at 11:11 am -
Dave Jones
November 28, 2011 at 11:29 amThanks Mike
I couldn’t find that for the life of me, and then I unclicked “Match project video aspect ratio” and all of a sudden I have the Quicktime .MOV options.Thanks
Dave. -
Mike Kujbida
November 28, 2011 at 2:00 pmDave, that’s a “fix” that I’ve never come across but I’m glad to hear that you got it working.
