Activity Forums Apple Final Cut Pro Legacy H.264 to something FCP likes
  • H.264 to something FCP likes
    Posted by Daniel Persson on March 8, 2010 at 10:22 am
    Hey I need some advice about converting h.264 to something final cut can edit, but also has the best quality,Prores tends to do the job but i heard there is some other codec which is better. The team is using a canon eos 7d which apparently delivers files in h.264. What codec should I convert to?
    Rafael Amador replied 16 years, 5 months ago 2 Members · 3 Replies
  • Rafael Amador
    March 8, 2010 at 12:12 pm
    As long as there is not any 8b Unc 420 codec (no that I know) the perfect codec is Apple 8b Unc, if you can bear the data rate.
    Prores still being the best option.
    rafael
    http://www.nagavideo.com
  • Daniel Persson
    March 8, 2010 at 1:20 pm
    Okay thanks, do you know anything about colors and what the optimal option is when you are shooting on the 7d? I’ve heard prores changes the color slightly.
  • Rafael Amador
    March 9, 2010 at 2:20 am
    I heard, I heard..
    Stop hearing and try by your self, and if you find a problem look for an answer.
    rafael
