Activity Forums Apple Final Cut Pro Legacy H.264 to ProRes
  • H.264 to ProRes
    Posted by Jesse Gordon on April 2, 2010 at 8:55 pm
    Hi –
    Received several folders of video clips from a Still Photographer.
    h.264
    30 fps
    640×480
    Not sure what camera, assuming NOT Mark II because clips not HD.
    I want to convert to ProRes before editing,
    but so far haven’t hit upon the right recipe.
    ProRes same framesize/framerate = crazy shift when playing/parked on frame
    ProRes 720×486 looks degraded stretched out.
    Any ideas for best conversion settings would be greatly appreciated.
    Jesse Gordon
    Jesse Gordon replied 16 years, 5 months ago 3 Members · 3 Replies
  • John Fishback
    April 2, 2010 at 9:11 pm
    Here’s how I’ve done it. It works very well. Import the file to Compressor. Use an H.264 preset and change it to:
    Audio Encoder
    16-bit Integer (Little Endian), Stereo (L R), 48.000 kHz
    Video Encoder
    Format: QT
    Width: 720
    Height: 480
    Pixel aspect ratio: NTSC CCIR 601/DV (16:9)
    Crop: None
    Padding: None
    Frame rate: 29.97
    Frame Controls On: It takes time, but this is important.
    Retiming: (Best) High quality Motion Compensated
    Resize Filter: Statistical Prediction
    Deinterlace Filter: Best (Motion Compensated)
    Adaptive Details: On
    Antialias: 0
    Detail Level: 0
    Field Output: Same as Source
    Codec Type: Apple ProRes 422
    Multi-pass: Off, frame reorder: Off
    Automatic gamma correction
    Progressive
    Pixel depth: 24
    Spatial quality: 50
    Min. Spatial quality: 0
    Temporal quality: 0
    Min. temporal quality: 0
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Mike Kahn
    April 2, 2010 at 9:26 pm
    Is it possible it was recorded using the 5D? Cannon released a plug in for FCP to use log and transfer to transcode to prores from H.264 using their camera.
  • Jesse Gordon
    April 2, 2010 at 9:28 pm
    Possible, but I would expect HD files from a 5D.
