Activity Forums Apple Final Cut Pro Legacy H264 Sluggish Playback
  • H264 Sluggish Playback
    Posted by Ben Mullins on December 5, 2011 at 4:48 pm
    I’m having a problem when playing H264 files back in Quicktime 7 on a PacPro (3GHz Quad, 5GB RAM). They look slightly sluggish and the audio appears very slightly out of sync. When played in VLC they look fine. They also play out of sync on the clients PC (what is the best codec for PC playback?). A typical file would be 1280×720, 25fps, 5000kbps, 250Mb, 48kHz audio. Source is P2.
    Any suggestions would be most appreciated.
    Ben.
    Joseph Hung replied 14 years, 9 months ago 2 Members · 4 Replies
  • Joseph Hung
    December 5, 2011 at 5:05 pm
    Is it QT 7 Pro and up to date? maybe lower your kbps.
    http://www.tulpapictures.com
    Twitter: @tulpapictures
    Facebook: http://www.facebook.com/tulpapictures
    Mac 2.66 GHz Quad Intel Xeon
    OSX 10.6.8
    FCS2
    CS5
    8GB RAM
    ProAvio 8TB RAID 5 Dual Mini-SAS
    Blackmagic Intensity Pro
    ATI Radeon X1900
    RocketRAID 4322 via dual MiniSAS
    Panasonic Lumix GH2, Canon 5DMKII, 7D, Panasonic HVX200A, Panasonic DVX100A
  • Ben Mullins
    December 6, 2011 at 8:22 am
    Hi Dave,
    Sorry if I was misleading, I’m not editing with H264 it’s the playback in Quicktime that I have a problem with.
    Ben.
  • Ben Mullins
    December 6, 2011 at 8:24 am
    Yes, Quicktime 7 Pro. I’ve tried encoding at the smallest bitrate I can without losing quality but it doesn’t make any difference.
  • Joseph Hung
    December 6, 2011 at 5:20 pm
    Are you using the Quicktime H264 codec through Compressor? Are you outputting a self contained full resolution QT then bringing it into Compressor for the transcode? I personally avoid using the “Send To Compressor” setting.
    OSX 10.6.8
    FCS2
    CS5
    8GB RAM
    ATI Radeon X1900
