Activity › Forums › Adobe After Effects › H.264 Renders really REALLY slow.
  • H.264 Renders really REALLY slow.
    Posted by Simon Roughan on March 12, 2014 at 2:08 pm
    Hello All,
    Ive been having to render more and more stuff out as HD H.264, and the render times are atrocious.
    Ive given up on trying to get it to render straight out of AE, as it always crashes when making a Quicktime H.264. So now I’m trying to export to media encoder, and do it there.
    A three and a half minute film is showing me it will take 54 hours.
    The comp is not particularly complex, a couple of pre-comps with jpegs and videos, a ray traced comp so I can curve a pre-comp, HD 720p .mp4 material is also in there…
    Has anyone an idea whats up with this`?
    My machine specs…
    Adobe CC, updated.
    HP Z820 workstation, Dual Xeon E5 processors-32 threads, 64 gigs RAM,
    Nvidia Maximus setup (Quadro 6000 and a Tesla C-2075)
    I think I have enough under the hood that this job shouldn’t be a problem.
    Any help appreciated.
    You know I’m born to lose, and gambling is for fools, but that’s the way I like it, baby. I don’t want to live forever!
    Simon Roughan replied 12 years, 6 months ago 2 Members · 5 Replies
  • Roland R. kahlenberg
    March 13, 2014 at 1:07 am
    I’m not 100% certain but AME doesn’t take advantage of GPU processing when a ray-tracing comp is rendered in AE.
    Additionally, rendering out H264 via AME, from an AE comp will require AME to first render, internally, an uncompressed version of the comp and then using this file to render a H264 version. IOW, there is no direct route from AE to H264, via AME.
    You should render out a high-quality movie from directly AE. Then use the resultant movie, in AME, to render to H264.
    HTH
    RoRK
    Latest AE Workshop – MoGraph Intensity – Shapes & Text
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
  • Simon Roughan
    March 13, 2014 at 9:41 am
    Thanks heaps for the tips guys, I will play around a bit now with the comps..
    mfg
    Simon
  • Simon Roughan
    March 13, 2014 at 4:16 pm
    HI Guys, I hope you see this Post!
    Just one more quick question.
    Are you saying the best workflow that you know to get HD out of After Effects is first to render the film as Upper Field First, and a Lossless Quicktime, say Animation Codec? Then taking that Quicktime into AME and making deliverables that way?
    Thanks for your time
    mfg
    Simon
  • Simon Roughan
    March 14, 2014 at 8:44 am
    Hi Dave,
    I left this thing overnight to render, got in this morning to find this message:
    This is the main reason I have trouble with rendering HD in AE, and end up having to export sequence to AME.
    AE always has these strange crashes halfway through. It had already rendered for 46 mins and had made a 3.5 gig file before it broke down with this strange “output module failed” message. Oh well….
    I will re-render now with a tiff sequence, then import it into AE and then try to render a Quicktime.
    On Edit:
    I can render SD Quicktimes without a problem.
  • Simon Roughan
    March 14, 2014 at 4:28 pm
    No, the drive is NDFS. The size is not the problem, its the codec. Somehow, Animation doesnt want to play the game. I tried with the Black magic 10 bit codec, and with the YUV 4:2:2 and they both worked. But when I try with Animation, it always breaks down. Well at least now I know.
    Thanks again for the time you take to answer.
    mfg
    Simon.
