Activity Forums Adobe After Effects h264 render/export problem
  • h264 render/export problem
    Posted by Johan Hoogendoorn on September 13, 2007 at 1:59 pm
    when I render to an h264 .mov from AE, the resulting movie is way too bright, and downright ugly
    by the way, the same problem occurs when I convert to h264 from qt, using an intermediate render (say with anim codec)
    in qt settings, all filters are disabled
    max quality..
    jjh
    Johan Hoogendoorn replied 18 years, 11 months ago 2 Members · 3 Replies
  • Shawn Rossi
    September 13, 2007 at 3:08 pm
    Are you by chance on a workstation running WinXP Pro 64-bit? I am posting similar issues with QT codecs. However, mine are coming out too dull.
  • Johan Hoogendoorn
    September 13, 2007 at 9:04 pm
    no, it’s WinXP pro 32bit
    I did a test on my other (older) computer, same OS, and results are normal as far as I can see
    no ‘washed colors’ at all..
    strange,..
  • Johan Hoogendoorn
    September 16, 2007 at 2:25 am
    hi rossimo,
    this https://forums.creativecow.net/readpost/2/916314
    SOLVED the issue for me too, it seems
    so, thanks!
