Activity › Forums › Adobe Premiere Pro › H264 Render Times
H264 Render Times
Posted by Paul Rozon on October 24, 2011 at 2:27 pmI have a Matrox-MXO2LE on a fairly powerful system and H264 rendering is taking longer then real time. Is this consistant with other users of Matrox-MXO2LE?
Paul Rozon replied 14 years, 11 months ago 2 Members · 4 Replies -
Jeff Pulera
October 24, 2011 at 5:04 pmHi Paul,
Does your MXO2 have the MAX option? If not, then Matrox has no bearing on the H.264 export times.
My experience using CS5 or CS5.5, on a Core i7-2600 machine with Nvidia graphics (Mercury GPU) is that an HD timeline going out to web formats is roughly realtime, while encoding to Blu-ray takes maybe 1.5x realtime.
If you have older PC technology, like Core i7-9xx technology or older, or do NOT have an Nvidia GPU, then it will take longer.
Jeff Pulera
Safe Harbor Computers -
Paul Rozon
October 24, 2011 at 5:42 pmYes I do have the max board and the computer is new. Sounds like I am getting the same results as you on blurry.
It is a new system and i Just wanted to be sure my system was performing properly.
Jeff Pulera
October 24, 2011 at 6:17 pmHi Paul,
Make sure you are choosing a Matrox export preset to take advantage of the MAX hardware. The “Matrox 264 for Bluray” profile should be realtime. Using any of the Adobe-native H.264 presets will not use the MAX hardware.
Jeff Pulera
Paul Rozon
October 26, 2011 at 3:07 pmJeff
Thanks for the heads up on the Matrox export settings. I did not notice them. I went straight to the H264 encode.
Now that I know they are there I have gone to use them and video is disabled on matrox bluray and matrox Mp4. I know I purchased the MAX board and the Matrox unit has the MAX logo on it. Is this an indicator that the Board is not activated in some way?
