Activity Forums Apple Final Cut Pro Legacy h264 QuickTime Pro export vs Compressor
  • h264 QuickTime Pro export vs Compressor
    Posted by Dean Goldsworthy on September 2, 2010 at 8:09 pm
    I exported from an HDV source to a 640×360, 1200kbps, .h264 file from Quicktime Pro and the result looks fantastic, but it is slow.
    So I tried the same thing in Compressor (same size and data rate) but the text within my video (a fairly thin font) has jagged edges no matter what data rate I try.
    What is going on?
    I want to take advantage of Qmaster virtual clusters and render quickly.
    Thanks for any input you may have.
    John Fishback
    replied 16 years ago
    2 Members · 3 Replies
  • John Fishback
    September 2, 2010 at 8:37 pm
    Did you have Frame Controls on in Compressor? If not, turn them on and set the Resizing quality at best. If the frame rate is different in the exported file also set the Retiming quality setting to better or best. Test a small portion to see if that helps.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Dean Goldsworthy
    September 2, 2010 at 9:13 pm
    Thanks for your input John. That has it looking 70% better.
    I then adjusted the deinterlace to “better” and that has it looking just like the QT export!
  • John Fishback
    September 2, 2010 at 9:14 pm
    Glad it worked out.
    John
