Activity Forums Compression Techniques h264 QuickTime Pro export vs Compressor
  • h264 QuickTime Pro export vs Compressor
    Posted by Dean Goldsworthy on September 2, 2010 at 8:09 pm
    I exported from an HDV source to a 640×360, 1200kbps, .h264 file from Quicktime Pro and the result looks fantastic, but it is slow.
    So I tried the same thing in Compressor (same size and data rate) but the text within my video has jagged edges no matter what data rate I try.
    What is going on?
    I want to take advantage of Qmaster virtual clusters and render quickly.
    Thanks for any input you may have.
    Dean Goldsworthy replied 16 years ago 2 Members · 2 Replies
  • Daniel Low
    September 2, 2010 at 8:39 pm
    Impossible to say without you giving more information about what settings you’ve used. Possibly you’ve used multi-pass in QT and not in compressor.
    BTW. Read the posts at the very top of this forum.
  • Dean Goldsworthy
    September 2, 2010 at 9:12 pm
    I turned Frame Controls on and set the Resizing quality to best.
    I then adjusted the deinterlace to “better” and that has it looking just like the QT export!
