Activity Forums Blackmagic Design H.264 Pro
  • H.264 Pro
    Posted by Scott Francis on April 19, 2011 at 12:24 pm
    Anyone use this to capture from the optical of a camera and encode bypassing internal camera compression. Wondering if this is a better format than HDV (quality wise)
    Scott
    Scott Francis
    Scott Francis
    Mind’s Eye Audio/Video Productions
    Alex Gerulaitis replied 15 years, 4 months ago 4 Members · 4 Replies
  • Danny Hays
    April 19, 2011 at 2:41 pm
    I answered this on the Sony Vegas forum. Take a look.
  • Luke Maslen
    April 19, 2011 at 11:54 pm
    Hi Scott,
    H.264 is full resolution codec and will store a full 1920 x 1080 pixel image. By comparison, HDV deliberately loses some of the picture and saves it at 1440 x 1080 to keep the data rate low.
    HDV uses 4:2:0 chroma subsampling whereas H.264 Pro Recorder uses 4:2:2 so the color is better with H.264.
    This does not mean that you should rush out and convert all your HDV material to H.264 but if you have a choice of acquiring new material in one format or the other, I would suggest choosing H.264.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Scott Francis
    April 20, 2011 at 12:08 am
    I have not been able to see and “system requirements” on this unit..I currently capture via firewire to laptop and tape on my Sony FX1’s. The picture I see is MUCH nicer on my component preview than the HDV codec that I am recording to. What are the computer requirements for this unit? I have some older laptops that do fine with HDV, and since it is a hardware converter, is the computer just capturing data?
    Thanks for your help!!
    Regards
    Scott Francis
    Scott Francis
  • Alex Gerulaitis
    April 20, 2011 at 12:34 am
    Ditto, don’t see minimum system requirements. At the very minimum (pun intended), would like to see “any computer with a USB 2.0 interface able to capture up to 480Mbit/s (60MB/s)”.
    It would be great to know the minimum OS requirements; how to set or change encoding data rates if possible; what are the pre-set or maximum encoding data rates for a given incoming signal.
    Alex (DV411)
