Activity Forums Compression Techniques H.264 maximum bitrate
  • H.264 maximum bitrate
    Posted by Darren Coombes on January 20, 2012 at 12:56 am
    Hi, I have been given settings to encode a video for adstream delivery here in Aus, that requires the bitrate to be 15,000 kbps or higher for a h.264 output. I use the following settings, but cannot get an output that’s more than 10.9 mbps. Any help? Does QT have a maximum bitrate for h.264??
    settings:
    h.264
    framerate: 25fps
    keyframes: all
    best quality: multipass
    data rate: restrict to; 25000 kbps
    sound: 48/16
    Craig Seeman replied 14 years, 8 months ago 3 Members · 2 Replies
  • Jason Brown
    January 20, 2012 at 1:23 am
    I believe it depends on your h264 profile. The profiles have a maximum dimension and I’d guess the same is limited in regards to bit-rate.
    Although I’ve not seen this setting accessible anywhere else than with Matrox Max settings that I use in Compressor. Maybe Episode Pro could get you there as well.
  • Craig Seeman
    January 20, 2012 at 1:36 am
    I just delivered to Comcast with H.264 15,000kbits High Profile from Episode Pro.
    Compressor 4 can do H.264 .mp4 up to 30,000kbits although Main Profile, not High. There’s no High Profile option in Compressor.
    Matrox MAX can target 50,000kbits.
