Activity › Forums › Apple Final Cut Pro Legacy › H264 incongruence
  • H264 incongruence
    Posted by Rafael Amador on October 9, 2011 at 1:32 pm
    I’m playing with some GoPro stuff (H264) and once conformed the sequence to the footage I found that the sequences gets forced to RGB rendering.
    If I change to any of the YUV rendering options the sequence asks for rendering.
    Do somebody a que on what is going on?
    H264 is YUV (YCbCr); Why to be managed as RGB?
    Rafael
    http://www.nagavideo.com
    Rafael Amador replied 14 years, 11 months ago 2 Members · 2 Replies
  • Shane Ross
    October 9, 2011 at 6:51 pm
    Raf, you of all people know you can’t edit H.264 natively
    Shane
  • Rafael Amador
    October 11, 2011 at 11:00 am
    [Shane Ross] “Raf, you of all people know you can’t edit H.264 natively”
    Sure Shane, but you know that certain unsupported stuff works, as long as you don’t try to make funny things.
    The GoPro stuff plays great in FCP. You can cut it, and even applying some filters, in a Prores sequence without problem.
    What I point is just to a technical incongruence, but doesn’t affects editing.
    H264 is a YUV codec, but asks for RGB processing.
    When you conform a sequence (Compressor: H264), the settings shows “Render in 8b RGB”.
    If you just change to render in YUV (8 or High Precision), the sequence need rendering even if you haven’t done nothing (filters, motion tab,..).
    Is like you conformed a sequence to an Animation clip, and the setting would show “Render in 8b YUV”.
    Must be a reason, but I can’t figure it out.
    I have to try with H264 from other source.
    rafael
