Activity Forums Adobe Premiere Pro H264 frame size
  • H264 frame size
    Posted by Michael Goldberg on July 3, 2014 at 5:31 pm
    I have a long timeline, and I’m compressing to H264. It’s 1080, and I tried to encode a version at 1/2 size, the encoded file is the same file size as the full 1080 encoded H264. Can I not reduce the file size by encoding a 1/2 or 1/4 size version?
    Mike
    Marcin Grabos replied 12 years, 1 month ago 4 Members · 4 Replies
  • Marcin Grabos
    July 3, 2014 at 8:00 pm
    yes, you can, but instead of changing preview settings try to set new size in the export window 🙂
  • Tero Ahlfors
    July 4, 2014 at 4:29 am
    Resolution does not matter in compressed formats. The bit rate does.
  • Jorn Bergmans
    July 4, 2014 at 8:59 am
    While resolution may change the size of your exported file a little, as Tero mentions, the most important thing here is the bitrate. Compressed formats don’t just save pixel information flatout, so half the pixels doesn’t always mean half the filesize.
    You can increase compression by lowering the bitrate, expressed in mbit/s or megabits per second, meaning less data will be used per second of video and your file will be smaller in the end – fewer bits * same amount of seconds.
    Be aware that this will decrease the quality of your overall image, so more artifacting etc may occur.
  • Marcin Grabos
    July 4, 2014 at 1:36 pm
    Ups, sorry, I didn’t read carefully so my answer is pointless. Tero is right, lower the bitrate and estimation of file size will appear at the bottom of export window (bellow the “use frame blending”).
