Activity › Forums › Compression Techniques › H.264 for WD TV via Compressor
  • H.264 for WD TV via Compressor
    Posted by Daniel Edelman on January 25, 2012 at 3:50 pm
    Hello Friends. I’m trying to put together a .mov H.264 file for a client. Unfortunately I don’t have the unit to test with so I have to get it right. He will be playing it off a Wester Digital TV Live, into a large plasma screen. Anyone have any experience with this unit and could give me a hand designing a profile in Apple Compressor? Primarily video bitrate.
    Computer – Mac Pro 2x 3Ghz Intel Quad Core, 6GB Ram
    Operating system including exact version number- Max OS X 10.5.8
    Software used including version number – Compressor from FCS v7
    Source codec (file you put in) – 1080i 59.94 Apple ProRes HQ Quicktime
    Destination codec (file you want out) – H.264 Encoded MOV
    Type of destination use – looping video played out of a “WD TV Live” into a large plasma
    Jason Brown replied 14 years, 8 months ago 2 Members · 1 Reply
  • Jason Brown
    January 28, 2012 at 1:29 am
    Ironically, a post popped up in FCP forum with the same sort of question:
    https://forums.creativecow.net/readpost/8/1152317
    I’ll post my reply here as well, I think it’s relavent:
    I use a legacy version of the WDTV, the one before all of the network connectivity stuff they introduced.
    Almost 2 years ago, I wanted to discover the limitation of the box, so I did multiple tests and I was able to run h264 in .mov container at 45Mbps without any issues on playback (from USB drive). I didn’t go any higher…because that is more than enough and reaches the limitation of Blu-ray in terms of bit-rate.
    The only tweaky things I did discover was in using my Matrox MAX accellerated compression…if I compressed with the generic mp4 compression setting in Compressor, it worked fine. If I used the Matrox codec to encode to, I had audio cutting out with bit-rates above 3-4Mbps (using AAC audio) other audio codecs worked fine. I tracked this down to the fact that “hinted streaming” needed to be enabled. I think this was only a limitation when using the Matrox hardware to speed up compression from what I remember. The Matrox folks were awesome in helping me track that problem down.
    My company uses these for tradeshow video playback…so I have developed a clean workflow for encoding for them.
    -Jason
