Activity › Forums › Compression Techniques › h264 Fade Up Looks awful
  • h264 Fade Up Looks awful
    Posted by Jm Knowles on May 2, 2010 at 6:56 pm
    I am preparing a video to be run off a lap top for a presentation. After consultation here (thanks everyone) I decided to go with H.264.
    However, the fade into my piece looks terrible (and there are a lot of artifacts as well.) I uploaded the first 4 seconds or so here
    https://www.extravaganzacreative.com/Milk2//H264test1.mov
    I exported directly out of final cut pro. Here are my export settings and also original sequence settings.
    https://www.extravaganzacreative.com/Milk2/settings/
    I wonder again, am I using the right codec for presentation (H.264?) I have used Compressor before but have not really played with the settings. Are there tweaks I can do in there to get this to look better? Or in FCP? Any help is very much appreciated!!!!!!
    Jm Knowles replied 16 years, 4 months ago 2 Members · 9 Replies
  • 9 Replies
  • Daniel Low
    May 2, 2010 at 7:35 pm
    A few observations:
    Exporting from FCP is never going to give you good results. Use compressor!
    I’m confused by the use of a DV frame size (720×480), square pixels and an anamorphic flag.
    You should be using a frame size like 720×400 square pixel – that will give you a correct 16:9 (1.77:1) frame. At the moment your frame aspect ratio is 1.5:1 which is neither 4:3 or 16:9 but somewhere in between.
    Correct the frame size, use compressor and things will look much better.
    If you need help with frame sizes look at the post from Craig at the top of the forum.
    Sent from my iPad Nano.
  • Jm Knowles
    May 2, 2010 at 7:53 pm
    The use of my frame size 720 by 480 square pixels was an aesthetic decision … as this was not for broadcast and presentation only I thought that I would have the flexibility to do this. At this stage of the game I am locked into that aspect ration (unless I recreate all of my graphics from scratch.) Is this going to be a problem?
  • Daniel Low
    May 2, 2010 at 7:55 pm
    [jm knowles] “Is this going to be a problem? “
    No.
  • Jm Knowles
    May 2, 2010 at 7:59 pm
    Thank you Daniel. When I get into Compressor is there anything I should watch out for. Should I set keyframes to automatic, or to some other figure to get best quality. I am setting everything to best so far ..
  • Daniel Low
    May 2, 2010 at 8:05 pm
    Keyframes to automatic. Forced keyframes at 10x your frame rate so in your case every 300 frames or every 10 seconds, if you still have problems with fades (which you should make last at least 2 seconds) reduce that to every 150 frames
  • Jm Knowles
    May 2, 2010 at 8:31 pm
    Thanks much Daniel I will give it a try!
  • Jm Knowles
    May 2, 2010 at 9:49 pm
    I followed your advice and everything looks great. Thanks for being around today and sharing your advice Daniel. It was very much appreciated.
  • Daniel Low
    May 2, 2010 at 9:52 pm
    My pleasure.
    Please rate my posts 😉
  • Jm Knowles
    May 2, 2010 at 10:08 pm
    I didn’t know I could do that (and I guess I owe some other people some cows too when I get a few minutes to spare!)
    Done. Thanks again.
