Activity Forums Adobe Premiere Pro H264 Export
  • H264 Export
    Posted by Y. Bar on June 21, 2010 at 6:39 am
    Hello,
    I am exporting a short animation , based on Quicktime animation codec files.
    The export settings are Quicktime, H.264 – 100 percent quality,
    1920 x 1080, square pixels, set bit rate – maximum.
    yet I get a very low quality result..
    can anyone help ? (I am using Premiere CS4)
    Thanks, Y.
    Y. Bar replied 16 years, 3 months ago 2 Members · 2 Replies
  • Mike Velte
    June 21, 2010 at 10:40 am
    Bitrate is the key…Set it to about 25 Mbps.
  • Y. Bar
    June 21, 2010 at 11:10 am
    I set it to the maximum which is 144,000 kbs and still I got a low result..
    After that I tried a different method- I used the H.264 option from the main menu (before it was Quicktime, and then H.264 as the codec).
    This worked , and I got a high quality mp4 file.
