Activity Forums Adobe Premiere Pro H.264 Export Settings Questions: Still Image and HQ Audio
  • H.264 Export Settings Questions: Still Image and HQ Audio
    Posted by Marc Walker on April 3, 2016 at 6:33 pm
    I want to render a video as H.264 for YT.
    – The video is of a still image with music.
    – I want the audio to be of highest possible quality, and the video to be a decent 720p image.
    – The audio format is 44.1kHz, 16 bit PCM.
    – The original still image resolution is greater than 1280 x 720.
    The questions I have are:
    • As the audio will be compressed, will I gain any quality by re-sampling the 44.1kHz PCM signal to 48kHz AAC)?
    • What AAC version is best for quality?
    • Given the video is a still image, does the frame rate even matter? Should I choose 10fps(the lowest)?
    • Should the target bit rate be lower for a still image?
    • What are the best ‘Key Frame Distance’ settings for a still image?
    Marc Walker replied 10 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
