Activity Forums Adobe Premiere Pro H.264 Export Problem
  • H.264 Export Problem
    Posted by Stamos Dimitro on September 27, 2013 at 3:19 pm
    So I am trying to export a short film that I recieved in a huge H.264 mov file (15gb, 7min) with premiere H.264 export option and despite I choose very high data rate (200-300 mb/s, Profile: High, Level: 5.1) I end up getting a 1,27 gb file after being assured that the export was succesfull. I tried it several times with different high data rates, I also tried adobe media encoder, but to no avail.
    Does anyone know why this is happenning and how can I fix it? Can you suggest any other export option that would give me a similar data rate (AVI is too big to play)?
    Ivan Myles replied 12 years, 10 months ago 4 Members · 7 Replies
  • 7 Replies
  • Angelo Lorenzo
    September 27, 2013 at 8:22 pm
    https://mediaarea.net/en/MediaInfo open your new file in here, switch to “text” view and paste the results.
    I would assume you’re encoding, or attempting to, such a high bitrate for a reason as to not start a debate. 300mbps is the maximum bitrate for the h.264 standard and, if my math is correct, the reason you received the 15gig file.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
  • Ivan Myles
    September 27, 2013 at 10:33 pm
    [Stamos Dimitro] “Does anyone know why this is happenning and how can I fix it?”
    When bitrate is not a constraint there is an inherent maximum determined by compression parameters (mostly internal) and GOP structure. Maximum bitrate occurs when key frame distance is set to one frame (all I-frame), and typically will be about 3-4 bpp (180-240 Mbps for 1920×1080-30p).
    I presume you are setting a high bitrate in order to maximize quality. After performing several tests I concluded that unconstrained H.264 High Profile with two-pass VBR and key frame distance set to about 12-15 frames produces virtually equivalent quality to an all intra-frame H.264 file. Bitrate should be about 0.75-1.0 bpp (45-60 Mbps for 1920×1080-30p).
    This might not be a consideration for you, but note that H.264 Level 5.1 does not play properly in QuickTime. Level 5.0 and below work fine.
  • Balu Gabbu
    September 29, 2013 at 5:32 am
    it is a good suggestion..
    i tried with that preset conditions and got a less sized video but missing some clarity in video
    which one should i rectify in above said preset for H.264exporting
    i need some clear video
    now by using 0.75-2.4bpp and 15keyframes it is somewhat blur to see…
  • Ivan Myles
    September 29, 2013 at 4:13 pm
    The following custom settings produce the maximum quality for the H.264 codec:
    – Format: H.264
    – Level: 5.1
    – Profile: High
    – Maximum Depth: Enabled
    – Target Bitrate: 300 (max)
    – Maximum Bitrate: 300 (max)
    – Key Frame Distance: 1
    – Maximum Render Quality: Enabled
    Set the parameters in the Multiplexer tab as follows:
    – Multiplexer: MP4
    – Stream Compatibility: Standard
    Click the “Queue” button to process the file using Adobe Media Encoder. When AME opens, click the green arrow to start the job.
    If the results are not satisfactory, please post some screen captures of bad frames in your encoded video.
  • Balu Gabbu
    September 30, 2013 at 7:19 pm
    ok thank you for info
    i will use it …
    its helpful:)
  • Balu Gabbu
    October 1, 2013 at 8:25 pm
    here in target bitrate you said 300(max)and for
    max.bitrate 300(max)
    is it mbps or kbps?
    if so
    it is showing a huge file size of 4056mb for a 6min video…
    is it supposed to be like that.
    balu… 🙂
  • Ivan Myles
    October 2, 2013 at 6:27 am
    It’s 300 mbps.
    Is the 4056MB an estimated file size before encoding or the actual file size after encoding? Actual file size will be less than the estimate when target bitrate is set to a very high number. If the actual file size is too high, increase the key frame distance.
