Activity Forums Adobe Premiere Pro H.264 export file size
  • H.264 export file size
    Posted by Jerel Peterson on December 18, 2010 at 4:35 am
    I’m new to H.264. I’m trying to reduce file sizes for some web videos. I was assuming that if I reduced the frame width and height to 1/2 (640 x 360 instead of 1280 x 720) I would get a smaller file size, but file size doesn’t change at all when I do that. Is there something else I need to change to get a reduced file size using this method?
    Mike Velte replied 15 years, 8 months ago 2 Members · 3 Replies
  • Mike Velte
    December 18, 2010 at 11:41 am
    The bitrate setting determines file size…bitrate is the amount of data in bits for each second of audio and or video. Convert bits to bytes by dividing bits by 8, multiply by 60 for 1 minute.
  • Jerel Peterson
    December 18, 2010 at 3:43 pm
    So if I reduced the height/width by 1/2, would reducing the bit rate by half (or 3/4) result in similar quality video–just in a smaller viewing size?
  • Mike Velte
    December 20, 2010 at 12:00 pm
    Your question is at the heart of the art of compression. There are few mathematical formulas, just trial and error. One formula is that both height and width should be divisible by 16.
