Activity Forums Adobe After Effects H.264 Export Error
  • H.264 Export Error
    Posted by Josh Pappas on August 15, 2009 at 6:48 pm
    I have a recurring issue exporting H.264 from After Effects CS3. Almost without fail, the export will get all the way to the end then give me two errors:
    After Effects: Out of Memory. (102400k requested)
    (23::40)
    After Effects: AEGP Plugin Media IO Plugin: UNRECOGNIZED EXCEPTION
    (5027::12)
    This only happens when I use the H.264 module to export. I can export H.264 from the Quicktime module fine, although I don’t prefer that. The issue happens in Adobe Media Encoder when I export from Premiere as well, and I can’t seem to pinpoint what is causing it. The projects I’m working on are short – less than a minute for most, one is about 10 minutes.
    It almost seems like a multiplexing issue, because it renders the entire file first, then seems to crash when it tries to create the mp4 container. It’s the best theory I have, anyways, although I have no idea what to do about it.
    Has anyone here seen this before?
    Josh Pappas replied 16 years, 8 months ago 2 Members · 2 Replies
  • Jc Jennings
    November 1, 2009 at 1:09 am
    Josh,
    Did you find a solution to this? I am experiencing this as well.
  • Josh Pappas
    January 14, 2010 at 3:27 pm
    No, I didn’t find a solution. My best bet thus far has been to export to a high-quality Quicktime format and export to mp4 from there, which is probably better from a workflow standpoint, anyways.
    Josh
