Activity Forums Compression Techniques h.264 Export Desaturated/Washed Out
  • h.264 Export Desaturated/Washed Out
    Posted by Shawn Romano on August 23, 2008 at 6:16 pm
    Hi. I am using Quicktime Pro v.7.5 to export h.264 video. The compression itself is beautiful, but I have consistently had problems with the h.264 footage getting desaturated and slightly washed out. I have attempted to compensate for this by adding a filter in the QT export, which does help but takes much longer to render. Has anyone else had this problem? How can I address this issue so that what I’m exporting better matches my source footage?
    Daniel Low replied 18 years ago 4 Members · 9 Replies
  • 9 Replies
  • Ed Dooley
    August 23, 2008 at 6:57 pm
    Do a search for Gamma H.264 in this forum and the Compression Techniques forum. There are plenty of posts discussing it. It’s a well-known problem.
    Ed
  • Shawn Romano
    August 23, 2008 at 8:42 pm
    I did find a fix that worked. I just adjusted some settings in the exported QT. Thanks!
  • Daniel Low
    August 25, 2008 at 11:58 am
    Would you care to share with us what you did?
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
  • Shawn Romano
    August 25, 2008 at 12:45 pm
    Sure. I found a post about this issue on Andrew Kramer’sVideo Copilot blog.
    Here’s what it said to do, and it worked: After rendering into a QuickTime/h.264 file, open it up in QuickTime and select “Show Movie Properties.” Highlight the video track then click on the “Visual Settings” tab. Towards the bottom left you should see “Transparency” with a drop-down box next to it. Select “Blend” from the menu then move the “Transparency Level” slider to 100%. Choose “Straight Alpha” from the same drop-down and close the properties window and finally “Save.”
    Pretty sweet.
  • Daniel Low
    August 25, 2008 at 8:10 pm
    Yup, that’s a good fix, however Apple needs to get on top of these faults, as well as building a class leading H.264 codec before too long, Quickime H.264 is the bottom of the pile for quality and profile/level support. Workarounds like this should not be needed at this level. QuickTime is the best format out there and Apple needs to pull their finger out. Quickly.
  • Shawn Romano
    August 25, 2008 at 8:28 pm
    If I might inquire, what do you mean by “Quickime H.264 is the bottom of the pile for quality”? I assumed that it was one of the better compression codecs, seeing that it is a Blu-Ray format and all. Is there a superior compression technology out there?
  • Daniel Low
    August 25, 2008 at 9:32 pm
    Sure,
    H.264 is a standard, just like MPEG-2. There are a bunch of implementations from various groups and commercial organisations that produce H.264 codecs.
    A list is available here
    Apple is to be praised for bringing H.264 to the masses long before Blu-Ray or HD-DVD, but they have been lacking in features and quality support, much in the same way that iTunes MP3 encoding quality is easily beat by encoders like LAME.
  • Craig Seeman
    MainConcept H264
    Dicas H264
    are both better H.264 encoding.
    On the Mac side
    MainConcept is used in Squeeze
    Dicas is used in Episode
  • Daniel Low
    August 25, 2008 at 9:39 pm
    X264 is the best, according to expert tests. (and it’s free)
