Activity Forums Media 100 H.264 encoders
  • H.264 encoders
    Posted by Andy Taplin on May 12, 2006 at 1:01 pm
    I’ve seen some impressive encoding test using H.264 but the export option from QT7 won’t do two fundamental things for playback on a computer: crop and de-interlace. Are there any other encoder options that can do these for the Mac and or PC? Cleaner just seems to use QT’s settings.
    Andy Taplin replied 20 years, 3 months ago 2 Members · 2 Replies
  • Kieran Matthew
    May 12, 2006 at 11:41 pm
    I haven’t actually tried this properly, but it appears Compressor 2 can de-interlace and crop whilst converting to H.264. A quick test seemed to show it processing, but it was predicting an obscene amount of time for the batch to go through. Probably down to the 867 G4 i did the test on though.
  • Andy Taplin
    May 15, 2006 at 7:29 am
    Compressor is really slow at certain things – I never really got on with Compressor the quality seemed a bit suspect with MPEG-2 I thought.
    Actually I’ve found that Cleaner 6.5 will encode H.264 as an option in the QuickTime settings and it seems to work quite well.
    Andy
