Activity Forums Compression Techniques H.264 Encoder Comparisons
  • H.264 Encoder Comparisons
    Posted by Andrew Saliga on December 1, 2009 at 9:41 pm
    I’m testing out different H.264 encoders with settings meant to target the iPhone for playback over a cellular network. I guess this post is more of a “here are my results” kind of post rather than a question. Please do raise any questions that may come from this post.
    I’ll specify the video encoding parameters as they are what I’m interested in for this post.
    Main Concept H.264 – Sorenson Squeeze
    • 1,228Kbps
    • Multi Pass (I think Squeeze does 5-pass)
    • 480×272
    • Baseline@L2.1
    • 4 Ref Frames
    • Keyframe Every 300 and Auto on Scene Change On (Frequency 50)
    Sorenson H.264 – Sorenson Squeeze
    • 1,228Kbps
    • 1 Pass CBR
    • 480×272
    • Baseline@L2.1
    • 1 Ref Frame
    Apple H.264 – Sorenson Squeeze
    • 1,228Kbps
    • 1-Pass
    • Auto Key Frame On
    • 480×272
    • Main@L2.1
    • 2 Ref Frames
    x.264 – DV Kitchen
    I used the iPhone preset in this app, but settings according to MediaInfo are as follows.
    • 715Kbps
    • 480×270
    • Baseline@L3.0
    • 1 Ref Frame
    NOTES:
  • Apples encoder ditched frames. Frame count jumps from 881 to 892 and does not complete the encode, as the video’s last frame is 902!
  • Apple’s encoder changed the 29.97 fps video to 29.63.
  • Main Concept’s encoder handles the fade to black at the end horribly. Horribly! (Daniel Low, we’ve talked about this before, I still have not found a solution. Everyone seems to say the MainConcept H.264 or Dicas H.264 are the best, but I don’t see it in the MC encoder. I’ll run some more test and adjust key frame settings, although I’d think the 5-pass encode would solve this.
  • Here is a screen shot of my results. The image is dark because it’s 5 frmaes into the fade to black, just where the Main Concept encoder started to have issues. Left to Right, Top to Bottom…
    • Main Concept
    • Sorenson
    • Apple
    • x.264
    -Andrew Saliga
    Steelehouse Productions
    http://www.steelehouse.com (undergoing a much-needed redesign)
    http://www.vimeo.com/steelehouse
Andrew Saliga replied 16 years, 9 months ago 2 Members · 17 Replies
  • 17 Replies
    • Daniel Low
      December 1, 2009 at 11:16 pm
      Hummmmmm.
      Interesting.
      Can you do the same screen shots with the files opened in VLC rather than the QT player?
      And just so I’ve got the layout of the screen grabs correct, are you saying that bottom left is Apple and bottom right is x.264?
      “There’s no chance that the iPhone is going to get any significant market share. No chance.”
      Steve Ballmer To USA Today: 30 April 2007
    • Andrew Saliga
      December 2, 2009 at 12:00 am
      Yes, you are correct on the order.
      Here are the same files in the same order, but opened in VLC player. Whoa! Quite different.
      -Andrew Saliga
    • Andrew Saliga
      December 2, 2009 at 12:01 am
      Oh, sorry. I didn’t see a way to switch to frames. I did my best to get the screen grab as soon as the counter went to 29 seconds. This is right before the fade begins.
      -Andrew Saliga
    • Andrew Saliga
      December 2, 2009 at 12:06 am
      I’m not sure what it is, but when I scrub through a clip in VLC it gets that extreme artifacting. It’s not nearly as bad when it’s played back.
      -Andrew Saliga
    • Andrew Saliga
      December 2, 2009 at 12:14 am
      Maybe I should wait until I’m done testing to post, haha.
      So Sorenson encoded version will let me scrub and skip back and forth without any issues as will the x.264 encode.
      The Apple and Main Concept encodes to not, and the extreme artifacting is introduced.
      -Andrew Saliga
    • Daniel Low
      December 2, 2009 at 12:22 am
      Done correctly, x264 will be way ahead of all of the others.
      So my scoring would be:
      1st: x264
      2nd: Dicas
      3rd: Mainconcept/Sorenson.
      4th: Apple
    • Andrew Saliga
      December 2, 2009 at 12:33 am
      Here is a redo of the above screen shot without any scrubbing involved in playback. Main Concept on top, Apple on bottom.
      -Andrew Saliga
    • Daniel Low
      December 2, 2009 at 12:48 am
      Are you sure?
      Every other test I’ve seen would have Apple as the top picture and MC below.
    • Andrew Saliga
      December 2, 2009 at 12:54 am
      Sorry, maybe I wasn’t clear. If you look at the last two posts, you’ll see the encode setting in the file name at the top of the player window.
      MC has been on the top and Apple on the bottom.
      -Andrew Saliga
    • Daniel Low
      December 2, 2009 at 1:03 am
      I know. All I’m saying is, is that there is no way the Apple codec is better than the Mainconcept one. It’s a fact. Your settings MUST be different or the way Squeeze is addressing them must be different or something else
      Please see the below.
      https://www.nxtbook.com/nxtbooks/streamingmedia/0808/#/58
