Activity Forums Adobe Premiere Pro h264 compressions with Premiere CS5
  • h264 compressions with Premiere CS5
    Posted by Eddie Stein on October 19, 2010 at 2:31 pm
    Dear Creative Cow forum,
    Pardon the long intro. My basic need is to edit Canon HDSLR footage in Premiere Pro CS5 and use dynamic link with other applications. I am a seasoned Final Cut and Avid editor. I am now trying to learn Premiere CS5 (for work) by editing footage I shot with a Canon T1i (HDSLR). The footage is 1280 x 720 30p H264 codec. Initially, I compressed the clips to Apple Pro Res 422 and imported them into Adobe Premiere. I noticed that there were no presets for the Apple Pro Res footage, and I could not find a way to edit the sequence presets after the fact.
    I did see an HDSLR preset that matches my original camera footage. 6 months ago I edited native Canon 7D (HDSLR) footage in Final Cut Pro 7 and it was a nightmare. It seriously taxed my computer, and effects and subtitle renders were unpredictable. I would love to know if I will experience the same fate by editing H264 footage in Premiere Pro CS5.
    Also, I could not find a compressor or export function(other than export DV only) in Adobe Production Suite CS5. Am I missing something? Thank you for reading this long post, and most important, thank you in advance for your great advice.
    Eddie
    Dario Cincilla replied 15 years, 8 months ago 4 Members · 4 Replies
  • Andrew Devis
    October 19, 2010 at 7:08 pm
    CS5 is really good with a very wide range of formats including H.264 and you should find it nice and easy. Issues with multiple layers of H.264 can happen as the processors can get pushed to the limit if you try and do too many PiPs (picture in picture) but even so, if you have a reasonably good machine you should be fine if you keep it to 1 or 2 layers at a time – I’ve seen five layers working – just.
    As for export, first thing, select the sequence in the timeline and then choose file>Export>Media. This will open the Media Encoder and you can get any codecs you already have on your machine through that. Have a play and have fun. Andrew
  • Pablo Cabezas
    December 23, 2010 at 11:08 pm
    Good day, i am wondering how to edit in premiere cs4 or cs5 a avi file h.264 from the Benq DVM21 camcorder? ftp://files.benq.net/camera/datasheets/m21/m21.jpg
    When i import the file by the media browser or just importing directly premiere open it just like avi audio file with no video on it, i really need to edit a entire videoclip that i shot with this camera so please how can i visualize the movie and audio with a real time playback for this kind of format i see a lot of people is complaining about this format in premiere, hope to have a quick answer!
    here are the specification on the properties of the video
    File Path: C:\Users\Presentation\Desktop\december 23 2010\1-18 a.avi
    Type: AVI Movie
    File Size: 43.9 MB
    Image Size: 1920 x 1080
    Pixel Depth: 1920
    Frame Rate: 30.00
    Source Audio Format: 48000 Hz – 16 bit – Stereo
    Project Audio Format: 44100 Hz – 32 bit floating point – Stereo
    Total Duration: 00:00:27:05
    Average Data Rate: 1.6 MB / second
    Pixel Aspect Ratio: 1.0
    the computer specs that i am woking on
    Windows 7 professional 64 bits
    Intel® Core™ i7 processors
    8 GB of RAM
    1 tera RAID drive (2 hard drives 7200 rpm)
    Nvidia Geforce 285 GTX
    i found some solutions to work with H.264 file on some forums
    https://forums.creativecow.net/thread/3/900429
    i tried the solutions to work with cineform and convert the files but it didn’t work because it said is not a compatible file, converting to DV AVI format is still being slow for playback.
    The software that came with the camera TOTALMEDIA EXTREME2 has an editor on it and the it has real playback on real time but the editor is so basic and i need to make a music video and professional edits and effects, how can i see real playback on premiere with this files
    i upload one file so you can download to see if that works in your computer and hope get a solution to get edit this videos
    https://www.mediafire.com/?3724jwboge48kms
  • Pablo Cabezas
    December 23, 2010 at 11:34 pm
    8 GB of RAM
  • Dario Cincilla
    January 12, 2011 at 3:16 pm
    Hi Andrew, what you exactly mean for “reasonably good machine”? I’m buying a new pc and I would work editing in Premere CS5 the Canon 7D and 5D native footage. Do you think a system like this can work without problem?
    Processor: Intel Core i5 – 2,530 GHz
    RAM: 4 GB (to 8) – 1.066 MHz
    Video Card: Nvidia (model GeForce GT420M) – 1.024 mb (max 3.582 mb)
