Activity Forums Compression Techniques H.264 compression ratio
  • H.264 compression ratio
    Posted by Mike Sato on May 9, 2008 at 5:12 am
    Two questions:
    1. Anyone know what the approximate compression ratio is when a digital still camera uses H.264 to compress a 1280×720 video into a .mov file?
    2. If the average playback bit rate for 720×480 video on a standard DVD is 5 Mb/sec, what would the approximate MPEG-2 compression ratio be?
    Mike Sato replied 18 years, 4 months ago 2 Members · 5 Replies
  • Daniel Low
    May 9, 2008 at 12:10 pm
    1. Depends on the specs of the camera.
    2. Depends on the source.
    A = source
    B = compressed output
    Compression ratio is how much is ‘A’ compressed by to become ‘B’
    https://en.wikipedia.org/wiki/Ratio
    https://en.wikipedia.org/wiki/Video_compression
    https://en.wikipedia.org/wiki/Image_compression
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
  • Mike Sato
    May 10, 2008 at 8:20 pm
    Daniel,
    Thanks for your response. I am still unable to get even approximate answers to my two questions from those links though.
    Mike S.
  • Daniel Low
    May 11, 2008 at 1:04 am
    OK
    I’ll try answering it in this way:
    1. How many Megapixels is the camera and how many megabytes does 1 minute of 1280×720 H.264 video from that camera take up in space?
    2. What is the format, frame size and datarate of the source you used to create the MPEG-2 and how long is it in total?
  • Daniel Low
    May 11, 2008 at 1:19 am
    Actually, thinking about it, it’s impossible to answer question 1 without specific technical specifications for the camera.
  • Mike Sato
    May 11, 2008 at 7:32 pm
    > 1. Anyone know what the approximate compression ratio is when a digital still camera uses H.264 to compress a 1280×720 video into a .mov file? < >> Actually, thinking about it, it’s impossible to answer question 1 without specific technical specifications for the camera. << OK. Just looking for a ballpark answer if anyone has an idea. ============= > 2. If the average playback bit rate for 720×480 video on a standard DVD is 5 Mb/sec, what would the approximate MPEG-2 compression ratio be? < >> 2. What is the format, frame size and datarate of the source you used to create the MPEG-2 and how long is it in total? << Say a commercial DVD movie that is 2 hours long and has wide screen or 4:3 full screen pan & scan viewing options. =============
