Activity › Forums › Apple Final Cut Pro Legacy › h264 compression problem
Posted by Mitch Hardison on October 5, 2010 at 6:39 pmI am exporting my final render out of FCP .mov with h264 compression set to highest but for some reason my colors are getting washed out. This is first compression I have done on this video everything is out of AE full quality. The file looks great there but out of final cut the colors are not the same
Rafael Amador replied 15 years, 11 months ago 3 Members · 7 Replies -
Richard Keating
October 6, 2010 at 12:39 amThis is the imfamous QT Gamma Shift. Google that one and see what all the fuss is about.
Richard Keating
http://www.richardkeating.com
http://www.screenlight.tv -
Rafael Amador
October 6, 2010 at 1:34 am -
Mitch Hardison
October 7, 2010 at 11:26 pmRead a lot on the subject and found several ways to fix it but none of them worked. I bought quicktime pro and went through all of the steps from Video Copilot, checked the “Enable compatibility with FC colors” box and even downloaded x264 plugin and followed those steps. My video is still washed out. Why even do all the detailed color correction if its not going to turn out right. Any other suggestions would be great. I’m totally disgusted right now
Rafael Amador
October 8, 2010 at 3:36 amHi Mitch,
You can try the conversion with Compressor.
It has a gamma filter that you can adjust, and a Preview window.
rafael -
Mitch Hardison
October 8, 2010 at 12:11 pmOk I will try compressor. Thanks Rafael. Here is my last question. How do I render out full quality in FCP. Is proress the best. My file is 1280X720 usually straight from my JVC HM700. Thanks for your help
Rafael Amador
October 9, 2010 at 12:10 amUncompressed would be better than Prores, but is not a practical solution.
rafael
