Activity Forums Adobe Premiere Pro H.264 Compressed Mpeg-2 – 100 mbps ?
  • H.264 Compressed Mpeg-2 – 100 mbps ?
    Posted by Katherine Sweetman on September 17, 2012 at 6:03 pm
    I’m trying to make a non-standard sized 3D (3840×1080) H.264 compressed Mpeg-2 Container file for Netflix.
    Container
    • MPEG-2 TS
    • Video
    • Codec: H.264 100 mbps
    • Full-Resolution SBS: 3840×1080
    • Notice that the width is 2x of 1920 but the height stays the same at
    1080 compared to your 2D 1080 HD file
    Does anyone know if I can do with with Adobe Media Encoder or Compressor? Or… anything mac based?
    THANK YOU
    Katherine Sweetman replied 13 years, 10 months ago 5 Members · 8 Replies
  • 8 Replies
  • John Pale
    September 17, 2012 at 7:45 pm
    H264 is not MPEG2… It’s MPEG 4.
  • Katherine Sweetman
    September 17, 2012 at 7:52 pm
    Mpeg-2 Transport Stream…
    • Container
    • MPEG-2 TS
    • Video
    • Audio
    • Codec: LPCM
    • 8-channel
  • Vince Becquiot
    September 17, 2012 at 8:19 pm
    Once you have your H.264 file encoded, you can use tsMuxer to wrap into a Mpeg2 Transport Stream.
    Vince Becquiot
    Indigo Live
    San Francisco – Bay Area
  • Chris Borjis
    September 17, 2012 at 11:33 pm
    [Vince Becquiot] “Once you have your H.264 file encoded, you can use tsMuxer to wrap into a Mpeg2 Transport Stream.”
    That’s what I used once to deliver a 3D show for DirecTV.
    It worked. It was mpeg2 though not h.264
    September 18, 2012 at 12:37 am
    Will tsMuxer keep the H.264 encode?
    I can make it, but I can’t view it (very well crashes VLC), can’t find out if it kept H.264, and check if it’s still at 100 mbps…
  • Vince Becquiot
    September 18, 2012 at 12:40 am
    Yes, it’s only a wrapper.
    Vince Becquiot
    Indigo Live
  • Sneha Singh
    November 6, 2012 at 1:45 pm
    Hi!
    I have to deliver the eaxt same spec to Netflix.
    May you please let me the final workflow
    as I couldn’t even yet find an h.264 encoder that can
    do full resolution 3D SBS.
    Would appreciate any help.
    Sneha
    November 6, 2012 at 5:57 pm
    I ended up farming out to https://www.anytime-post.com/
    I believe they used telestream pro. Nothing I did on my own worked. Nothing from this thread worked.
