Activity › Forums › Compression Techniques › H264 Bitrate Limit
H264 Bitrate Limit
Posted by Andrei Popa on September 9, 2014 at 11:42 amHi there,
I have a 720P video that I have to encode in h264 with a bitrate of 12Mbps.
Is this possible?
The max I can get either in Media Encoder or Final Cut (quality settings maxed out) is 5Mbps in MOV format at 10Mbps in MP4 format.
If this is not the limit, how can i get a bitrate of 12Mbps with the H264 codec for a 720P video
Andrei Popa replied 12 years ago 3 Members · 8 Replies -
Ivan Myles
September 9, 2014 at 1:59 pmAre you using presets or custom settings? Please post screen shots of your export settings.
In AME with the H.264 codec use Level 3.2, Target Bitrate 12 Mbps, Maximum bitrate 18-25 Mbps, and 2-Pass VBR encoding. If using the QuickTime H.264 codec in AME or Compressor, set the bitrate to 12,000 kbps, Quality to 100, and Multipass encoding.
Andrei Popa
September 10, 2014 at 12:53 amHi Ivan,
I know what you are saying, I managed to do it, but I can’t duplicate it…
I did so many variations, and although I saved the good ones (or I thought so), it doesn’t seem to work…
I did it as a MOV file.
But now if I select the MOV file and the H264 container, I don’t get the level & bitrate options…
And I’m using custom presets, if I select MOV it just gives me PAL and NTSC presets…
Here is a screen shot of how I’m not getting the level and bitrate options…
https://postimg.org/image/819s1v52b/
When I did the proper file, if I remember correctly it was MOV H264 but I was getting the level/bitrate options
Eric Strand
September 10, 2014 at 1:41 pmAt the bottom of the screenshot, where it says Bitrate Settings, check that box and type in 12,000 kbps. I would also set Key Frames every 24 frames.
@ericstrand11
Andrei Popa
September 10, 2014 at 2:58 pmOk,
Now I know why I did it and can’t duplicate it or presets I saved do not work.
I did what you said, it worked once.
When I tried to do it again it did not work….
Meaning it was a low bitrate (like 3k) although limit said 20k…
So for some reason neither AMC or Compressor seem to “load” the presets, or make the bitrate changes specified in a custom setting…
So the bitrate appears high in the setting, but it’s not having any effect with the actual encoding…
Eric Strand
September 10, 2014 at 3:03 pmThat’s odd. You’re absolutely sure the Limit Date Rate is checked on? Like it’s lit up, not greyed out? You’re hitting okay when you’re done changing the settings and not cancel? Or you’re not clicking match source settings before you hit okay?
@ericstrand11
Andrei Popa
September 10, 2014 at 3:33 pmYep…
I’ve been losing hour on end trying any possible combination.
There’s definitely something wrong with my software.
What I don’t understand though is why both AMC and Compressor exhibit the same behavior, if it was only one of them ok, but both… that’s extra odd..
I actually tried it on 2 different OSX’s (Snow Leopard and Mountain Lion, have 2 drives with 2 systems) and still the same…
Eric Strand
September 10, 2014 at 4:44 pmWow that is really bizarre. Maybe upload a screen capture video of what you’re doing? I have not heard of that behavior before. Sorry Andrei
@ericstrand11
Andrei Popa
September 10, 2014 at 8:55 pmIt is indeed very bizzare…
I’ve lost at least 8 hours trying to figure this out…
The thing is, that sometimes it does encode at the proper bitrate, but sometimes it doesn’t…
Basically out of at least 2 dozen encodings 3 were correct and the rest not…
I don’t think it’s the video since, sometimes it encodes it correctly.
Anyway, here is a link to one of the videos, they’re all basically the same content wise, this being the shortest one.
https://www.youtube.com/watch?v=Q5CbYbLQyl4
