Activity Forums Adobe After Effects H.264 best standard bitrate setting for render
  • H.264 best standard bitrate setting for render
    Posted by Yanda Satria on November 14, 2016 at 2:17 pm
    hi, i know this has been post many times, and i’m aware that exporting h.264 from AE isn’t recommended…i’ve been searching the internet, and haven’t really found an answer yet…
    but, currently i am working regularly with client, and he’s asking for mp4 format with h.264 codec…and he doesn’t like a large size file like .mov file…
    i am using AE Cs6..
    so, what is the standard bitrate setting for this?
    there are 2 setting right, target bitrate and maximum bitrate…
    what i’m using now is 20 for target and 25 for maximum bitrate…
    any better option / recommendation?
    and, what is exactly the standard setting for this? what is the standard bitrate setting for 1080p and 720p?
    i don’t know whats the video will be used for, he didn’t say…
    thank you… 🙂
    Yanda Satria replied 9 years, 10 months ago 3 Members · 4 Replies
  • Tudor “ted” jelescu
    November 14, 2016 at 2:28 pm
    Asking for the best bit rate without knowing what the video will be used for will get you nowhere. Find out what the renders will be used for- playback (and if so, on what), editing, some other post processing (grading, fx..) – then you will be able to get a specific answer.
    Tudor \”Ted\” Jelescu
    Senior VFX Artist
  • Yanda Satria
    November 14, 2016 at 2:31 pm
    on my previous project, he was using it for youtube though, so i’m guessing all this next project was also for youtube…since this is the same kind of project…
  • Daniel Waldron
    November 14, 2016 at 2:43 pm
    Media Encoder actually has YouTube presets under the H.264 settings. I would check those out. Just make your exports 2-Pass instead of 1-Pass, which is selected by default. I think it improves the quality, particularly if there is motion in your video. Pretty much every online video host like Youtube will recompress your video anyway, so I tend to keep the bitrate a little on the higher end (Minimum 16, Maximum 20).
  • Yanda Satria
    November 15, 2016 at 2:02 am
    i see, i’ll look into it, so 16 target and 20 maximum is good enough…thank you.. 🙂
