Activity › Forums › Compression Techniques › H.264 and Interlacing…help!
  • H.264 and Interlacing…help!
    Posted by Ed Yonaitis on June 25, 2008 at 6:29 am
    I’ve recently taken a job with a commercial production office; part of my responsibilities is digitizing commercial spots and uploading them to web. We have a Sony DigiBeta deck with an AJA Kona Lhe card set up with Final Cut Pro. Most of the stuff I’m importing was originally shot on film, so there’s obviously a pulldown taking place on the tape. I’m bringing them in 720×486 @ 29.97 fps, with the Apple 8-bit Uncompressed codec. The quicktimes look interlaced when I bring them in, which I figure, “Hey, makes sense, it’s uncompressed, two fields, should be interlaced”.
    I use these settings when exporting with Compressor:
    Quicktime movie
    H.264 codec
    Key frame rate: Automatic
    Multi-pass
    29.97 fps
    Data rate: 1200 kbps
    Fast start streaming
    I’m also sure to check Deinterlacing under the filters, with sharp algorithm selected.
    The resulting exported quicktimes still look like crap! The picture quality looks OK in terms of sharpness, but I’m getting awful interlacing lines on the edges of anything that moves in the frame. It’s driving me nuts, because I know I’ve seen good H.264 stuff exported before without interlacing. Can anyone tell me what I’m missing here?
    Any help would be greatly appreciated!
    Ed Yonaitis replied 18 years, 2 months ago 2 Members · 2 Replies
  • Daniel Low
    June 25, 2008 at 2:59 pm
    Use the Frame Controls settings in compressor to deinterlace rather than the deinterlace filter.
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
  • Ed Yonaitis
    July 2, 2008 at 9:01 pm
    That worked great, thank you!
