Activity › Forums › Apple Final Cut Pro Legacy › H.264 accelerator
H.264 accelerator
Posted by Michael Calvino on June 26, 2007 at 4:30 amAnyone know of a H.264 accelrator for the mac…?
Jerry Hofmann replied 19 years, 2 months ago 4 Members · 6 Replies -
13
June 26, 2007 at 5:07 am -
Michael Calvino
June 26, 2007 at 5:26 amyeah I have checked it out and looks promising…
except for the limited output presets, which dont seem
to have a setting for any real video profiles PAL or NTSC…I need 720X576 or 1024X576 …? any other ideas…?
Jerry Hofmann
June 26, 2007 at 5:57 amThings speed up big time with an 8 core machine, and it’s even faster with a cluster… Compressor 3 will just scream on an 8 core. It’s faster than real time… if you cluster it it’s even faster.
That’s probably why there’s not much choice out there for accelerators…
Jerry
Uli Plank
June 26, 2007 at 8:15 amWe tried the Elgato and didn’t find it too impressive (as good as their other products are). When there’s lots of motion it tends to get blocky, Compressor is better.
Regards,
Uli
Michael Calvino
June 27, 2007 at 7:19 amThanks,
thing is I work on a laptop mainly a 2.16 core duo…maybe I should upgrade to a core 2 duo…Would make a big difference yeah?
Also does compressor 3 show significant encoding speeds over the last version?
Jerry Hofmann
June 29, 2007 at 5:08 pmI don’t think you’d see a dramatic difference upgrading to a slightly faster computer… but I’m seeing compressor 3 REALLY speed up on an 8 core when you setup all 8 processors to work at it in QMaster. .. a LOT faster than a dual.
Jerry
