Activity Forums Adobe Premiere Pro H.263 encoding
  • H.263 encoding
    Posted by Stamos Dimitro on May 25, 2016 at 2:19 pm
    So I have been asked by my client to deliver the finished video in these awkward specs:
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom
    File size : 156 MiB
    Duration : 2mn 56s
    Overall bit rate : 7 413 Kbps
    Encoded date : UTC 2014-09-30 19:46:29
    Tagged date : UTC 2014-09-30 19:46:29
    Writing application : Lavf51.12.1
    Video
    Format : MPEG-4 Visual
    Format profile : Simple@L1
    Format settings, BVOP : No
    Format settings, QPel : No
    Format settings, GMC : No warppoints
    Format settings, Matrix : Default (H.263)
    Codec ID : 20
    Duration : 2mn 56s
    Bit rate : 7 411 Kbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.143
    Stream size : 156 MiB (100%)
    Writing library : Lavc51.40.4
    Language : English
    After some research I realized that Premiere has the option for MPEG-4 export (different than H.264 export), but the settings are very limited. Specifically it won’t let you make the resolution more than 720×576. So how can I export the requested file?
    Mike Buckhout replied 10 years, 3 months ago 2 Members · 2 Replies
  • Stamos Dimitro
    May 25, 2016 at 3:26 pm
    Unfortunately the MPEG-4 option in adobe media encoder seems to be missing the necessary profiles to export the video I need (SEE IMAGE). H.263 encoding seems like a rare case and even though there are profiles to export HD video, Adobe premiere doesn’t offer them, so I wonder if anybody knows a plug-in or maybe another software to achieve this encoding.
  • Mike Buckhout
    May 25, 2016 at 5:25 pm
    It looks like the information you have was copy/pasted from MediaInfo, an app that tells you everything about an existing file. I would say they have this file and don’t really know how it was made, but they want you to make something new that will work with their system so they gave you the specs from that older file.
    Agree with Dave, just tell them you can’t do H.263 and send them an H.264 with the other specs matched up, like dimensions, framerate and overall bitrate. It should be fine.
    If they want a fixed target file size then the bitrate will have to be adjusted which I doubt is they really want.
