I’m just going to add a little here.
In FCP7 you were forced to transcode to prores – so FCP could edit well.
Transcode to ProRes
Put in ProRes Sequence
Output in whatever format you like.
Premiere Pro isn’t timeline/codec based in FCP was. If you want to work the prior way you could – with two encodes of your data – once to an editorial codec (such as Cineform, ProRes or DNxHD), once to your final output codec.
Transcode everything to ProRes.
Set Premiere Pro to create Previews (renders) in ProRes
BUT Premiere Pro can edit with the native files; for any previews, it’ll use the MPEG format – but when you output, it’ll ignore those preview files (unless you tell it otherwise) and output without any inbetween quality loss (by transcoding) to your output format.
Transcode nothing.
Edit in Premiere Pro – the previews (renders) will be ignored.
Only one encode of your data – meaning that elements like stills, generators and titles (which are handled uncompressed) only go out at maximum quality.
Best,
Jeff G
Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
You should follow me (filmgeek) on twitter. I promise to be nice.
New- my book (with Richard Harrington and Robbie Carman)- An Editor’s Guide to Adobe Premiere Pro
Compressor Essentials from Lynda.com
(older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
Contact me through my Website
