Activity Forums JVC Cameras GY HM100 SDHC cards
  • GY HM100 SDHC cards
    Posted by Kristof Vde on July 7, 2011 at 11:38 am
    I’m about to buy a GY HM100, so I’m also looking which SDHC cards to use. I know class 6 is the mininum, but I read there could be problems with higher classes, like class 10? Also, I found a website where they sell “class 1 HD” cards. Would these work?
    Second; what bitrate should the cards have? I know the camera can go up to 35Mbit/s, which I assume, is when it records in 1080p. So the cards should also have a minimum of 35Mb/s?
    If there are users here who can share there experience with this camera and these SDHC-cards, that would be great.
    ps: just checking: the camera actually records in 720p and then upscales to 1080p, right?
    Krisse
    André Engelhardt replied 15 years, 1 month ago 2 Members · 3 Replies
  • André Engelhardt
    July 7, 2011 at 5:05 pm
    Hi Kristof,
    the JVC GY HM100 takes both class 6 SDHC cards or class 10 SDHC cards. The ability to use class 10 cards was added with a firmware update but should be standard on all currently shipping models.
    I’ve been using SanDisk class 6 cards for 1 1/2 years now and never had any issues. Others have used cheaper cards and have reported good results as well.
    Class 1 cards obviously being neither Class 6 or 10 would not work.
    The “class” states the transfer speed of a SDHC card so your question about the bit-rate is that it needs to meet class 6 or 10 spec which is 6 MB/s for class 6 (48Mbit/s) and 10MB/s (80Mbit/s) for class 10 cards. 35Mbit/s as the camera shoots would equal 4.375MB/s)
    See https://en.wikipedia.org/wiki/Secure_Digital#Speed_Class_Rating for more info.
    And yes, the CCD’s in the HM100 are 720p resolution that get scaled up within the camera (which does a really good job at it too!)
    Hope that helps.
    André
    Audio Engineer, Sound Designer
    Video- and Photographer
    http://www.andreengelhardt.net
  • Kristof Vde
    July 9, 2011 at 9:57 am
    Thanks for the answer.
    I do have a bit of a dillema right now: since Sandisk is quite expensive I want to go with Transcend cards (half the price, good rep). But I’ve read about incompatibility problems of those class 10 cards, that aren’t fixed with the firmware upgrade. Should I go with the class 6 the, just to be sure?
  • André Engelhardt
    July 9, 2011 at 4:20 pm
    I know that Philip Bloom used Transcend class 6 cards in his review ( https://vimeo.com/4205284 ) and personally I have only been using class 6 cards and there is no problem with that. Class 10 is supported but not needed so by all means give the Transcend class 6 a shot.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
