Activity Forums Adobe After Effects Guys I need help with these points to make my logo beveled
  • Guys I need help with these points to make my logo beveled
    Posted by Bobby Sifon on March 29, 2022 at 2:20 am
    Image of project:
    https://files.fm/f/2tbjp43g4
    Alright guys this is a school project
    To make this animated logo beveled I was given the following points to achieve this
    1. Get rid of the green JPG and replace it with a green solid
    2. Pre-compose layer 1 (the animated PNG), moving all attributes to the new comp
    3. Delete the Black Solid (Layer 2)
    4. Set the Alpha Track matte for the Red Solid (now layer 2)
    5. Select the Bevil Alpha layer styles on the Red Solid and use the edit menu to Copy with Property links
    6. Reveal layer styles on the bottom layer (Green Solid) and delete Bevil Alpha
    7. Add the Set Matte effect to the bottom layer and choose the nested comp top layer as the source (your pre-comp)
    8. With the bottom layer selected (Green Solid) Ctrl/Cmnd + V to paste the Bevil and Emboss layer style and link all properties to the Red Solid layer (layer 2) so any adjustments you make on the Layer Styles settings in Layer 2 will show up in layer 3
    Ok guys I was able to follow the first 5 steps but I got stuck at number 6, 7 and 8. For number 6, What do I have to click to reveal layer styles on the green solid and what do I click to delete alpha?
    I just need to know what I’m to click to achieve these because as a newbie to Ae I’m not so familiar with some of the terms in Ae or where to find them.
    I just need a clear explanation for the steps in 6,7 and 8 or a video explanation please
    Files:
    https://files.fm/u/daye5rdwx
    Bobby Sifon replied 4 years, 5 months ago 2 Members · 2 Replies
  • John Cuevas
    March 29, 2022 at 3:07 pm
    If this is a school project, IMO your teacher has made a mistake with step 6.
    6-There is no layer style, Bevel and Emboss on that layer. —so skip this step. In step 2 you add a green solid, solids don’t start with Layer Styles or effects.
    Go to step 7 and work from there.
    When you are finished you should have a green logo that scale from filling the entire screen, then wiping to a red version of the logo. If I’m guessing right, he wants you to learn about the ‘copy with links’ function, where if you change the layer style of the red layer, it automatically updates the green layer. Saves time and you don’t have to do change the parameters on two layers.
    I’ve attached what I think is the completed project and if you want you can tell the teacher from me to be more careful when assigning his work.
  • Bobby Sifon
    March 30, 2022 at 4:48 pm
    Thanks for the help
