Activity Forums Adobe After Effects gunshot scene
  • gunshot scene
    Posted by Haiddd on October 2, 2005 at 8:56 pm
    hey,
    i’m trying to create a realistic gunshot scene. i want a guy to get shot in the head, and i want there to be lots of blood and wounds. how can i do this with after effects?
    thanks.
    Spockedit replied 20 years, 11 months ago 4 Members · 3 Replies
  • Kenny101
    October 2, 2005 at 9:54 pm
    from what i’ve seen done with AE…you won’t get realistic blood…thats where prosthetics and compressed air come in to play…
    A newbie AE6.5 user 😉
  • Oakmozart
    October 3, 2005 at 3:47 am
    Agreed. Get an airsoft pistol for realistic blow-back on the gun. Whip up some fake blood and make a “Guacamole gun” to create the gory effects from the gunshot. Use AE and Photoshop for the Muzzle flashes (or the Muzzle Blast effect from the “Delerium” Plugin Suite for AE from DigiEffects), and a good 3D app for the spent shell casings. VOILA! Realistic gun wounds. Yes, it’s a bit of a pain to get, but it’s worth it, because the end result will be SO much better if done with mechanical effects, as opposed to cheesy AE effects.
    Good luck.
  • Spockedit
    October 3, 2005 at 4:59 am
    If you cant afford the plug in you can draw muzzle flashes in photoshop and overlay them in AE using overlay or color dodge. Since they are only on for a few frames (make sure you dont use the same image for more than one frame) they dont have to look amazing..just good. As far as gun blow back, most of the Airsoft guns are way too slow. The chamer takes like a whole second to move back and forth. Just make sure the actor fakes it.
    As far as wound to the headh, you may be able to get away with using particular for the blood, if you make it look cloudy(like spray bottle) and quick. Track a black/red dot to the head, and obviously dont have a close up of it or anything.
    As you can tell I’ve done this before with pretty good results. I remember the producer screaming, “We dont have liability insurance for this!!” Excellent. Okay I made that last part up, but that would be cool.
    Spock.
